Question about Sharp Aquos LC-22SV6U 22 in. LCD EDTV
My sanyo aquos 32 inch flat screen won't stay on it keeps turning off a few secounds after i reset and turn on.
chrispurs1
  • 372 Answers
SOURCE: SHARP AQUOS 32 INCH FLAT SCREEN
Hi.
Easy fix do the following.
Set is in factory mode. To remove follow these steps below extracted from the service manual.
  1. Unplug the AC power cord of TV set to force power off.
  2. While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set. The letter K should have disappeared from the screen.
http://dysonmanuals.llc.nu/
Posted on Mar 30, 2008
SOURCE: vizio 32 inch flat screen
have you find out anything about it ?
Posted on Jul 24, 2008
SOURCE: i have a sanyo 32 inch flat screen television
you can order a replacement off of the website
Posted on Apr 04, 2009
  • 53 Answers
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Posted on Apr 30, 2009
I had this problem as well guys. Just found a fix thought i'd share.
I simply went into menu>setup>reset . This will perform a factory reset, and you shouldn't have that K or the volume problem anymore.
I tried all the fixes involving volume- input- nothing worked. I tried volume- ch- but that K never changed colours.
It all came down to a simple menu option reset.
Posted on Aug 21, 2009
I have a sharp 32 inch and the green flashes and when i hold down the input and channel down it shows red then i push down the power button hold it goes orange then green it comes on then shuts back off
You don't want to keep doing that because you can make it go into a coma and not turn back on again. It may not work to perform a factory reset INIT (industry initialization) but call sharp aquos 877-322-7867 (87seeaquos) to get a case file created and be walked through an INIT including resetting the lamp errors. If the rep has you read the number of lamp errors and it is not zero then you should be scrolling down and resetting them to zero before changing screens to turn INIT on.
Sep 29, 2011 | Sharp Aquos LC-C3234U 32 in. LCD TV
My tv won't turn on, it will if i hold in the power button and will only stay on a few seconds, then flashes green
Bad capacitors on power supply board they will be vented or swollen on Top. 1000uf 2200uf 10v 3300uf 10v
May 31, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My sharp aquos lcd tv 32 inch usually gets hard time in turning on coz once a brownout occurs and when i turn it on only the green light appears without pictures so i have to unplug it on and off as...
Sounds like you have bad capacitors somewhere in the TV. If none of them are bad, you could also have loose grounding screws on the inverter shield. It is common for this TV and simply retightning them will keep the backlight on again.
Mar 23, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Tv keeps turning on and off
You probably have blown capacitors on the PSB-power supply board. Recaping with new UF caps works 90% of the time. The set turns itself of into a fault protection to keep from damaging more components internally. A few bucks a soldering iron some solder should do the trick.
Jun 29, 2010 | Sanyo DP50747 50 in. Plasma TV
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
32 inch Sharp Aquos Screen is cracked. Can it be
Yes, however, the Display is as much as a new set.
Oct 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-22SV6U 22 in. LCD EDTV Logo
185 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
