Question about LG 42LC5DC 42 in. LCD Television
Aux input not available - LG 42LC5DC 42 in. LCD Television
Don't know how to use aux option in 08 s550 ME Benz
First, you should locate the aux button or touch screen display for the aux and press it. If it reads no aux available or something similar then your model has the button but not the aux input itself. If it reads not connected, look for the aux port (looks like a headphone jack) in the center console region. after plugging in your device, simply hit aux and enjoy!
May 02, 2011 | Car Audio & Video
Kenwood Kdc-mp425 will not switch to Aux. Aux cable is connected to the back of the headunit, but no aux option is available on menu for either my ipod touch or my sirius unit. I've accessed the menu from...
Apparently, this auxiliary input only works for a Kenwood CD changer or a sirius radio connection. At least that is my conclusion after finding the same problem. Let me know if you figured anything out on this.
Jun 02, 2010 | Kenwood Sirius KDC-MP425 CD Player
Trying to hook up my wii to an very old model phillips magnavox
I think you have two options here:
1-Maybe your TV aux input is the type where the AUX channel is before channel 2, or after whatever your highest channel number is. If so, you can access that AUX channel by either going channel UP or channel DOWN.
2-If that doesn't work, maybe it's worth the $5 for a cheap universal remote, that you can program, and thereby access the TV INPUT mode.
Hope this helps.
Mar 06, 2010 | Philips 19PR19 19" TV
How do i connect my iPod to receiver sony strdg510- there is no aux port in receiver
You can connect it to any one of the input sources on the receiver. It doesn't have to be AUX. For example, you can hook it up to the CD input (#5 below).
The Ipod can be on any input that you have available, just make sure the receiver is set to that input on the front to correspond with whichever one you decide to use. If you have no available inputs to use, go to RadioShack, you will be surprised at the little connectors they have to allow you to split inputs and outputs to use two devices, etc. very inexpensively.
An alternative, disconnect one device to hook up the Ipod to that input when needed.
I hope this helps and good luck!
Feb 28, 2010 | Sony STR-DG510 Receiver
I have an Onkyo TX-SR501 and have purchaed the Audio Y-Cable but can't seem to figure out how to play my Ipod through the receive. I cannot find an AUX connection. Help.
Aux is just a generic label for any unassigned high-level (non-Phono) input. They're all electrically the same as the 'labeled' inputs.
Use any of the following instead (whatever is available and convenient): CD; Tape 1 In; Video 2; Video 1 In - then selct the appropriate function to hear the program.
Dec 05, 2009 | Onkyo TX-SR506 Receiver
Can't receive pic and sound with the converter box.
The tv should be on channel 3. Otherwise, you can go to menu on tv, then find "autoprogram" and it will search all available channels. Usually tv should be on channel 3 if hooked up with a coaxil cable and aux or AV or Input if you are using rca jacks.
Jul 08, 2009 | Televison & Video
Little and poor quality sound from turntable
Turntables do not produce "line level" audio which is what is required for input into the AUX on the receiver. If you do not have a phono input on the receiver, you must purchase a phono pre-amp. These are readily available for about $20. This will boost the output of the turntable to line level so you can use the AUX input on your receiver. That will resolve the problem.
Dan
Feb 23, 2009 | Panasonic Audio Players & Recorders
Changed car battery & Kenwood execolon kdc-X592 AUX is gone
Try pressing 'menu', scroll to "built in aux", and toggle to the 'on' position. Then the aux input should be available again. The radio losing power would have reset any internal memory causing it to go back to factory defalts. Hope this helps
Dec 03, 2008 | Kenwood Excelon KDC-X592 Car CD/ MP3...
I have a Kenwood KDC MP2035, it is brand new, I try listening to somehting plugged into the AUX but when i press SRC to select AUX, AUX does not show up, only TUNER and STANDBY are in the options so far
here is some thing that will help u out. AUX Input: The KDC-MP2035 is equipped with a front panel 3.5mm minijack auxiliary input for connecting external portable audio devices such as an MP3 player or Tape walkman. The receiver allows you to select between the following AUX settings.
  • Off: the source button does not scroll through the AUX input when function is turned "off"
  • Aux 1: turns on the AUX input for use
  • Aux 2: turns on the AUX input in the attenuator mode - press the attenuator button to activate sound. pleas let me no if i can help any more and dont be afraidto rate me i dont bite lol just kidding
Apr 09, 2008 | Car Audio & Video
LG 42LC5DC 42 in. LCD Television Logo
574 people viewed this question
Computer Repairing
Computer Repairing
