Question about Arris SURFboard SB5120 Modem
Reset Motorola SURFboard SB5120 Modem - Arris SURFboard SB5120 Modem
    Sergeant:
  • 231 Answers
This is a direct link to show you step by step how to reset the modem http://www.ehow.com/how_5125713_reset-sb-modem.html I hope this helps good luck
Posted on Sep 30, 2010
Benimur
  • 6966 Answers
SOURCE: motorola surfboard sb5120 usb driver problem
Hi, Create a temporary folder say C:\Motorola and put all your unzipped Motorola USB drivers. Install your Cable Modem. If and when Windows asked where the drivers may be located, point to the C:\Motorola. If your modem has already been installed and operational and you simply want to update its current drivers > go to Device Manager and right click on your modem to update, likewise point to the C:\Motorola. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 30, 2007
  • 3 Answers
SOURCE: Cannot set up Motorola Surfboard SB5120 modem
This usually means something is not correct with your incoming signal. If your cable wire into the modem is being run off an amplifier in the wall this could be effecting your service. If the signal is too strong the modem won't be able to communicate for internet.
You could check the incoming wire to see if it is running off an amplifier. If it is you would need to run a new line that is not on the amplifier. I would recommend comcast coming out to check the signal frequency and make the necessary adjustments.
Posted on May 04, 2009
SOURCE: Cable modem Surfboard SB5120 Motorola
If you are not using the usb connection option for this modem, no drivers are required.
Posted on Jul 14, 2007
  • 34 Answers
SOURCE: Reconnecting to internet after recovering from sleep mode
There are many causes of this, but the most common can be solved by going to the CMOS (BIOS) of your computer and disable the power saving on the ethernet, PCI or wathever where you modem is connected.
Posted on Jul 18, 2009
YourZEN
  • 820 Answers
SOURCE: how to open settings of motorola SURFboard SB5120
Support for the Motorola SB5120, discontinued product, see next site:
http://broadband.motorola.com/consumers/support/default.asp?supportSection=DiscontinuedProducts
Connecting the device, see the "Quick Reference Guide":
http://broadband.motorola.com/consumers/products/SB5120/downloads/SB5120_Quick_Ref_Guide.pdf
For installing the modem the easiest way is to run the provided cdrom.
When not available perform the settings as showed in the guides.
Motorola 5100 series user guide:
http://broadband.motorola.com/consumers/products/SB5120/downloads/SB5120_User_Guide.pdf
See page 7 "Before You Begin" for the requirements and selecting either USB or Ethernet connection.
Page 22 gives the overview for the pages how to configure ethernet settings.
Posted on Oct 31, 2009
I need driver for usb motorla sb5120 on vista
Hi, check this URL hope it will be helpful
http://download.cnet.com/Motorola-SURFboard-SB5120-USB-Cable-Modem/3000-2112_4-170001.html
Oct 26, 2010 | Arris SURFboard SB5120 Modem
Cox says my SB5120 is resetting 12 pulse times a
May be firmware get corrupted due to power-cut or an excess voltage or surge problem.
At times when there is thunder-storm a lot of excess volatge is generated on the phone wire which is link down to the modem
Ok
try to download recent firmware from manufacturer and see if it can be updated.
Cheers
Uttam
Jan 14, 2010 | Arris SURFboard SB5120 Modem
How to reset moorola modem sb1520 surfboard
hi, to reset the modem follow these steps.
step 1 : Turn the Motorola Surfboard SB5120 Cable Modem so that the back of it is accessible to you. There's no need to disconnect any of the cables.
step 2 : Find the "Reset" button on the modem. It's a small recessed button located between the USB port and the cable outlet.
step 3: Use a pointed instrument to push the button. Hold it for 10 to15 seconds to allow time for the modem's indicator lights to go off.
step 4 : Release the Reset button. The lights will gradually begin to come on as the modem connects to the communications channels between the cable provider, the computer and the Internet provider. When all the connections are made, the lights will stablize.
step 5 : Release the Reset button. The lights will gradually begin to come on as the modem connects to the communications channels between the cable provider, the computer and the Internet provider. When all the connections are made, the lights will stablize.
Nov 22, 2009 | Arris SURFboard SB5120 Modem
How to open settings of motorola SURFboard SB5120 modem?
Oct 31, 2009 | Arris SURFboard SB5120 Modem
Jul 18, 2009 | Arris SURFboard SB5120 Modem
Motorola sb5120 trouble
the sb5120 does not have a reset button- you just unplug the power cord and plug it back in to reboot it, it is a modem not a router. click start-run- type: cmd and click ok then a black box will come up and type in: ipconfig and press enter and that should give you your ipaddress of your router if you are connected through a router
Jun 02, 2009 | Arris SURFboard SB5120 Modem
Update driver, for Motorola Surfboard SB51520
hi richard there is search on the internat dorry i cant rmber the site
Nov 12, 2008 | Arris SURFboard SB5120 Modem
Motorola SURFboard SB5120 MTU problem
do a hard reset.
hold the reset button for 15 seconds plugged in.
keep pressing the button and unplug the modem.
keep pressing for 15 seconds.
plug it back in but keep pressing for another 15 seconds.
This should have hard reseted the modem.
now try the 192.168.0.1
Aug 25, 2008 | Arris SURFboard SB5120 Modem
Arris SURFboard SB5120 Modem Logo
3,379 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
