Question about Toshiba SD-K860 DVD Player
Every DVD gets stuck with "Loading"
Any DVD or CD I try gets stuck and the player says "Loading". I notice that the disc does not seem to spin at all! Is the player toast?
- Vivek
  • kjrschoen Mar 28, 2009
  • Anonymous Mar 20, 2014
    I cannot get the loading mechanism of the DVD player to open I need to pry it open
  • 149 Answers
Could be just the mechanism that detects whether theres a disc in.
Have to open it up to find out tho, not a good idea unless you know what youre doing.
Posted on May 25, 2008
Everytime i play the disc, it would say loading , then after 10seconds the tray disc would open and say cannot read disc. please check the disc
Put in an ordinary audio CD and play to notice if the CD is detected. If yes the optical is working, if not there is no laser scanning and the possibility that the laser head can be defective.
Now certain cleaner disks will not be tracked to run for cleaning as it is not read. Hence it will reject. So it is ideal to clean manually the laser head eye using a cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Feb 09, 2011 | Samsung BD-P1500 Blu-Ray Player
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Loading but nothing happens
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.I hope this information helps your problem.
Apr 07, 2009 | Mintek MDP-1810 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Loud mechanical noises from my dvd player during loading,advcing,
hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
Feb 07, 2009 | Philips DVP5140 DVD Player
Prism DVD-352P not loading any disks
What you are hearing is the attempt to read the disk. The unti detects that a disc is present and attempts to read it by spinning it first at CD speeds then at DVD speeds. It will attempt this a number of times before giving up and reporting "no disc". If you can get at the optics, try cleaning the lens using a cotton swab and alcohol. Next try to read a CD. If you can read a music CD and not a DVD, it indicates that the optics are starting to fail and need to be replaced.
Dan
Dec 18, 2008 | Televison & Video
Disc gets stuck on "loading"
laser lens may need cleaned or realind! claen and try again
Dec 12, 2008 | Televison & Video
Won't load
My player was doing the same thing and I noticed that the lens arm was stuck near where the disc snaps into place. I gently pushed the arm away from the center (being careful not to touch the lens). I restarted the dvd player and put a disc in...started right away.
Aug 13, 2008 | Sony DVP-FX810 Portable DVD Player
Shows Loading menu after switch ON and nothing comes out as results
looks like it has a problem reading the disc
what sort of disc are you trying to play
try with an original DVD and see the results
May 26, 2008 | LG DVD 6183 DVD Player
Toshiba SD-K860 DVD Player Logo
610 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
