Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I have a icemaker that floods. It will quit flooding when power is off so I think the fill valve is okay. Is there a way to fix this icemaker? And am I on the right track. Thanks,
  • GE Master
  • 2,696 Answers
You have a bad water valve.when the ice maker calls for water the valve is staying stuck open
Posted on Sep 30, 2010
Testimonial: "I'm going to check it out. Thanks so much. "
Smeg Dishwasher constantly filling and tripping anti flood sensor
Fill solenoid if water constantly filling when power switched off. Level sensor in sump if just overfilling but stops when power off
Jan 19, 2018 | Smeg Washing Machines
Why did ice maker flood, then stop getting water?
The flooding was the water control valve letting you know it was about to fail. Now, it has failed closed. The failure could have been caused by buildup of mineral deposits from the water source.
Mar 22, 2016 | Refrigerators
My washing machine wont fill up with water.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Dec 30, 2010 | Hotpoint Washing Machines
Ge s/s icemake floods water
Icemaker generally has only about a 6 second fill time. Most likely a particle made it past the screen in the fill valve and would not allow the internal diaphram in the valve to seal. You can't get to the internal parts of the valve. Replace the valve. Consider an in-line filter installation before the refrig hook up to prevent this from repeating.
Jun 14, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Water Flow out of freezer compartment
take wires off inlet valve if it stops replace ice maker
Aug 31, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Ice maker water line doesnt shut off
If the icemaker did not stop right in the spot where the water fills the tray, without completing the cycle, you have an icemaker problem, but that is highly unlikely. More likely is that the water fill valve (the part right where the water line hooks onto the refrigerator) will have to be replaced.
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
My maytag neptune sometimes fills with water and floods my floor
sjhtlh
It sounds like the water valve is starting to go. i would get a tech out just to make sure.
brent
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water sometimes does not shut off. flooded twice. happens intermittently.
If when the machine is flooding if you turn off power to the machine and it continues to fill: replace water inlet valve. If flooding water stops filling when power is interupted: clean out the end of the water level switch tube where it connects to the outer wash tub.
Sep 17, 2008 | GE WHRE5260E Top Load Washer
Whirlpool Icemaker flooding freezer
how much water and did you have to shut off the water supply to stop it
Mar 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice Maker floods floor and freezer compartment
You may not have got the supply tube all the way into position so I would check this first. If the water is running down the back wall of the freezer compartment at a higher level than the icemaker the problem is not with the icemaker but with some break in the supply chain. If the water is overflowing from the icemaker then it could be the timer cycle on the icemaker or the water inlet solenoid valve at the back of the cabinet (compressor side). Water leaks need to be traced back to the highest point ( I know how obvious that sounds but sometimes we all miss the obvious). Hope this is of some help.
Aug 16, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
269 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
