Question about Acer AL1715 17" LCD Monitor
Vertical positioning setting is frozen
I can reset horizontal screen positioning, but the vertical screen positioning is frozen. Auto config does not help.
    Genius:
  • 1,224 Answers
Lets see what i can do
sometimes under the screen edge either side or bottom they have the menu buttons these have become hard to find but there on your screen on one of the buttons the select should be de gaus (spell check) this sends a powerful power signal to monitor to reset its self some times its scary to watch but when it does that it should release the buttons parameters back to working state then use the buttons to set your parameters
the other thing is there is something stuck or broke in the button which was pushed a little harder then most
if this is the case
and you dont want to mess with monitor then take to computer tech. they will tear down and replace button backing sometimes the button backing points break off or disalign do to tomuch preasure on the button
i hope this helped you
Posted on May 26, 2008
My Kindle only shows the books horizontally on the screen. When I turn the Kindle, the words do not move into the vertical position.
There is probably a rotation screen lock in the settings if this is on the screen will not rotate when the tablet is turned to the desired position the option should be in the settings menu need more info to determine where in the settings it is at
Jan 24, 2015 | Tablets & eReaders
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
I need to reset my margins for Windows XP
Your monitor should have a button on it that says "Auto". Press that. If it doesn't have a button like that, then find one that says "Menu" and look through the Menu to find something like "Auto-config". Alternatively, you could use your monitor's menu to manually adjust the horizontal position of your screen.
Oct 18, 2012 | Dell Microsoft Windows XP Home Edition
Vertical lines appear on screen
if they are horizontal, there is a ground loop problem. plug the source and the projector into the same power strip. if they are vertical, the clock and phase are off. reset the settings to factory default. then select auto image.
Jul 14, 2009 | InFocus Office Equipment & Supplies
Cannot print...mmm...on this paper
The printer will not print the settings dependant on your media between 2 across. The printer figures you have one label wide enough to print the config page. Is there a reason you are trying to print this? You could set the printer driver to print to a file instead of the printer and get the settings that way. Or, if you are connected via TCP/IP, you can view it on the internal webpage of the printer.
Jun 22, 2009 | Zebra S4M Thermal Label Printer
Display wont expand to the left
What brand and model of monitor is it? Usually there is an auto config button that makes everything right. It is usually labeled Auto. If that doesn't fix it, press the menu button and see if you can increase the horizontal size and move it. If that doesn't work, take the monitor apart and reconnect the video cable that goes into the panel.
Jun 12, 2009 | Computers & Internet
My samsung yp-s5 has frozen when i was sliding out the speaker
You may want to reformat the memory.
If it persists try hitting reset(slide the speakers and you will see on the back a hole with reset written on it and push a pin in it)
Oct 15, 2008 | Samsung YP-S5JAB MP3 Player
Can not get a full screen lack 1 quarter inch on both side of the screen
just right click right in desktop and choice properties then setting and adjust the screen resolustion
Sep 28, 2008 | Computers & Internet
The positioning of my desktop's imageis still distorted despite running the easy tune display wizard and my using the auto tune keys on the side of the monitor.
Use the manual methods on your monitor (horizontal and vertical size and position), not the auto tune and see if you can get it to improve.
Try using a different desktop picture as well.
Right click on the desktop where there are no icons, and change the picture. Also, play with Stretch/Center/Tile - stretch will distort a file if it doesn't exactly match your screen settings.
Jul 17, 2008 | Gateway Computers & Internet
Monitor "offset"
try adjusting your refresh rate
Dec 13, 2007 | Acer AL1912 19" LCD Monitor
Acer AL1715 17" LCD Monitor Logo
175 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
