Question about Filter Queen Defender Air Purifier
Replace air filter warning light to reset? - Filter Queen Defender Air Purifier
    New Friend:
Honeywell HHT-145....above the circular window are 2 buttons/lights...the one on the left says "filter" and the one on the right says "UV bulb"...below the 2 buttons it says RESET....press those 2 buttons to reset the 'filter status'....it runs on usage and a timer...not an actual filter gauge monitor
Posted on Mar 23, 2013
  • John Mar 23, 2013
  • Yvonne Craig Jan 22, 2014
    what a silly situation. I was so frustrated that the filter indicator showed that my filters were dirty after I'd cleaned & reinserted them. The owners manual gives NO INFORMATION or instruction on HOW the filter monitor resets or what to do if you can't reset it. I was at a total loss. I performed your ABOVE suggestion & it WORKED. You have to hold BOTH the UV bulb & filter button, then the blue bars went from 3 back to 1 which indicates the filter is CLEAN. Thanks, otherwise I would not have been able to resolve this & calling Kaz is redundant as they only do customer service & parts ordering. They have NO TECH knowledge of the Honeywell air cleaners or products they sell.
    Problem Solver:
  • 10 Answers
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Posted on Jan 03, 2011
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Jun 07, 2016 | Honeywell Air Purifiers
I changed the bulb but it keeps saying replace bulb
Look through the settings to see if there is a reset option for warnings or for lamp warnings. Many products with lamps require you to not only replace the lamp but to reset the warning.
Oct 18, 2012 | Ecoquest Fresh Air Air Purifier
How do you change the filter? My in-laws have lost the instructions for their purifier.
You have a Honeywell air filter. Turn it over and there is a big handle which is a screw in the middle. Unscrew it and then lift the entire unit up without the outside screen protection. The filter will have a black pre-filter attached by velcro. Remove it, take outside put on the grass and hose out against the flow of air. (squirt from the inside out to remove stuff). Then use vacuum to blow the filter from inside to the out. Then vacuum the filter from outside in. Let the pre-filter dry. re-install in reverse. If there is a warning light, run on full, then push the warning reset for 10 seconds or more to turn it off.
Mar 01, 2011 | Duracraft DA5010 Air Purifier
I've replaced the filter. why won't the red replace filter light shut off?!
Remove the front cover and locate the FILTER RESET button above the dust sensor level indicator lights. Press and hold this button for 3 seconds until the unit emits a beep and the REPLACE FILTER light goes out.
Sep 03, 2010 | Winix PlasmaWave 5000 Air Purifier
How do I reset the "replace filter" light? I put a new filter in an don't know how to make the red light go out. Thank you
With the unit on - take off the front panel - right under where the "replace filter" light is, there is a button that says "Reset" hold that button in until it beeps - then the light should turn off. Hope this helps :)
Jul 31, 2010 | Winix PlasmaWave 5000 Air Purifier
Model 30375 replace filter light
There is a "RESET" icon next to the warning light. See the tiny hole? Get a small toothpick or something similar and simply insert, push, and watch the annoying light go out!
Jun 21, 2010 | Hunter 19' X 21' Room Air Purifier Air...
V5 filter replace - how to reset red flashing light?
So after you have replaced the V5 Cell Filter in the IQ Air, here are the steps you'll need to follow in order to reset the filter indicators:
  • At the main menu on the control panel, push the menu button 7 times until you get to the screen that says Replace Filter.
  • At the Replace Filter screen, press and hold the Enter Key until the cursor appears, and is flashing.
  • Press the UP arrow button on the keypad until you get to the V5 Cell Filter.
  • At the V5 Cell Filter screen press the Enter Key to confirm your filter reset selection. This will turn the corresponding filter LED to a flashing red light. IQAir requires that your reconfirm the filter selection to prevent inadvertently resetting the wrong filter. If you chose the wrong filter, press the menu key after pressing the enter the first time to disregard the filter change command.
  • To confirm the filter reset selection, press enter a second time, which will reset the filter life, and reset the filter hours.
You can repeat these instructions for the other two filters on your machine when it's time. Here's a link to the product manual for your IQ Air Health Pro Plus which will give you the same instructions, as well as other maintenance instructions.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/IQAir-healthpro-plus-owners-manual.pdf
I hope that this information was helpful to you. If you were able to reset your filter, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of my repair. This is what really keeps Fixya experts continue leaving free repair solutions. Thank you very much,
Chris J.
GoVacuum
Apr 08, 2010 | IQAir HealthPro Plus Air Purifier
I placed the filters back in , but the clean red light is still on. this is an ionic pro compact cleaner
Try unplugging it, for a few minutes and wait then plug it in again and see if it resets.
Otherwise you need to reset it.
Most appliances that displays warnings have to be reset after it is corrected.
even your trusty automobile check engine light.
good luck.
Jan 30, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Reset filter
    The solution is simple. Just press on the little red light that says to reset filter. Its a button that will reset the warning and the light should go out
    May 14, 2007 | Kaz Honeywell Tower Air Purifier with IFD...
    Filter Queen Defender Air Purifier Logo
    478 people viewed this question
    Top Filter Queen Air Purifiers Experts
    Colin Stickland
    Colin Stickland
    steve h woody
    Think Crucial
    Think Crucial
    Are you a Filter Queen Air Purifier Expert? Answer questions, earn points and help others
