Question about Optoma H30 Multimedia Projector
Vibration noise on optima Projectro/DVD unit
I have had the projector for about a year, and when I turned it on last it started up loud then sounded normal after running the projector for a while it started making this whinning vibration noise sounded like static on a speaker, but it sounded like it was coming from the fan. any suggestions.
  • 563 Answers
Hi mstadisasta
This is a faulty colourwheel that will have to be replaced as a colourwheel cannot be repaired.
It is quite easy to replace and I would suggest you to do it yourself if this unit is no longer under warranty.
All you'll have to do is get your hands on the new colourwheel from your local or nearest retailer.
Thanks for using Fixya !
Posted on May 26, 2008
Why does my projector make a very loud buzzing sound.
the buzzing sound will be a frequency vibration from the mains power cycles
check for loose connections, transformer mounts, loose bulb or any thing else that can vibrate
Apr 27, 2015 | Epson Powerlite 1720 Lcd Projector 3000...
My 3 year old Viking refrigerator starting making really loud noises today...what can I do avoid a repair bill???
If the loud noises sound like a fan blade hitting ice you have a defrosting problem.
You can try unpluging the unit removing the contents then doing a manual defrost with a fan blowing into the unit for a bit over 2 hours then restarting the unit to see if the noise has ceased.
If it is a noise associated with the compressor you can try pushing it gently in it's floating mounts to try and reposition the unit so the vibration absorbers are functioning properly again.
Lastly if it is the condensor fan making noises break out the crevice tool and remove the lint from the coils. If you have pets this is very important.
Sadly if the problem repeats in less than a week after doing the above the dreaded serviceman / repair visit will be required to islolate the cause or source.
Vikings' website:
http://www.vikingrange.com/consumer/footer/contact_us.jsp?id=cat50013
Thanks for using FixYa.
Kelly
Mar 07, 2010 | Viking 42 in Built In Professional...
Loud humming after turning on.
I have sort of the same problem...there was a loud snap(kind of electical spark like) then the unit started humming loudly which changes sound as you move the unit around. The picture remains clear and the fan is quiet in shut down mode...still the wheel you think?
Sep 07, 2009 | Optoma MovieTime DV10 Multimedia Projector
Optoma DV10 loud vibration and odd colours
check the colour glass wheel is shattered with a piece of glass still stack to the wheel. it not even thats why it vibrates
Aug 17, 2009 | Optoma MovieTime DV10 DLP Projector
Optoma ep716 loud noise
the colorwheel needs replacing. the bearings are shot.
Jul 25, 2009 | Office Equipment & Supplies
Optoma ep716 continuous loud vibration noise when turned on.
the fan motor could be failing. turn it on with the top off. if one of the fans is moving slower, that'd be the one. since this is a dlp projector, the colorwheel motor berings might be on their way out as well. both need replacement.
Jul 25, 2009 | Optoma EP706 Projector Remote Control
Ilo DVDR05 Vibration and loud humming noise
i experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
May 17, 2009 | iLO DVDR05 DVD Recorder
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
Loud Fan Noise
Review Date
Monday, 12th of September, 2005 --> What's Hot
User-friendly, built-in DVD player, high-throw ratio lens, fast power/cool down What's Not
Fan operation is quite audible, native resolution of just 480p The Final Word
A perfect coffee table companion Notes
# This product is no longer available directly from the manufacturer. It may be available in retail and distribution channels, or second hand. The price displayed is the price at review time and the last available recommended retail price.
The DV10 has a futuristic-looking outer casing and two internal speakers located behind a silver grille mesh at the rear. Heat is removed through its side ventilation and the internal fan has a noise level of 27dB, which is comparable to a loud computer and quite distracting when watching movies at low volume. At 368 x 117 x 273mm, the unit is small enough to permanently and inconspicuously reside on a coffee table.
this is from a review .
it sounds like that the fan needs to be cleaned the sound you hear is normal but if it sounds like its racein the moder might be on its way out if you have a can of air used to clean a key bored i would try to clean it out with that if not take it to a repair place to see if they could look at the moder
Jun 26, 2008 | Optoma MovieTime DV10 Multimedia Projector
Loud noise when it is in DVD player, low brightness
I had a similar sounding problem. When I opened it up I found that the segmented color wheel was missing the clear segment of glass. I have not been successful finding parts for it.
Dec 05, 2007 | Optoma MovieTime DV10 Multimedia Projector
Optoma H30 Multimedia Projector Logo
102 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
