Question about RCA P52926 52" Rear Projection Television
RCA p56926 replacement screen
I'm interested in replacing the black vinyl outer screen on my TV and wanted to know how I might go about purchasing one inexpensively?
Thanks,
Donnie
  • campsfamily Aug 17, 2008
    need to replace screen for RCA model # P60820BL
How do I remove a cracked outer screen on rca rear projection tv? So that I may replace it.
Posted on Jun 19, 2009
  • RCA Master
  • 8,617 Answers
You cant, the screens for that model are no longer available and even a used scree assembly will be over 200. if you could find a new one they would be about 4 to 500.00
Posted on May 25, 2008
Crescent shaped image on screen - RCA 56" P56926
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 07, 2010 | RCA P52926 52" Rear Projection Television
Rca p56926 screen is concave and cant adjust convergence in menu
Convergence can only be repaired by going into the unit itself....You MUST know how to do this or risk a lot more problems.....seek qualified assistance!
Aug 29, 2009 | RCA P52926 52" Rear Projection Television
How to remove screen on projection screen tv 56"rca model#p56926
Remove the speaker cover on the front, it just pulls off. Pry each side a little at a time. There are 4 screws that hold the screen on. Remove them and the screen just lifts off. There are wires attached to the controls so, keep that in mind when lifting the screen.
Aug 10, 2009 | RCA P52926 52" Rear Projection Television
Replacement screen for RCA d52w19
You will need the entire model number to see if the screen is avalible.. D52w19 + the ext number YX1 or yx2 or something like that it will be on label as model number but in smaller letters.
Nov 20, 2008 | RCA D52W19 52" Rear Projection Television
RCA P56926 Would not turn off
This tv make a lot loose connections. If you re solder and nothing change, check fly back area's is OK?... Look around convergence board for liquid coolant ( some times CTR liquid coolant projection splitter , becarfull, Liquid is danger!!) Wash yous hands and clean chassis with acetone.
Apr 19, 2008 | RCA P52926 52" Rear Projection Television
Xbox 360 hd and p56926
change back to 480 resolution and them go upscaling
Feb 20, 2008 | RCA P52926 52" Rear Projection Television
CRACKED SCREEN
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Dec 25, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca p56926 convergence problem
kraze3,
Your set has a repair issue with the convergence circuit.
Adjustments in the service menu will not help.............I agree
with Guest comment.... circuit board repair or replacement is
what you both need.....................T.
Nov 23, 2007 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
299 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
