Question about Dymo LabelWriter 450 Turbo USB Label 1752265 Thermal Printer
Dymo 450: the label prints about .5 inch too far left, although print preview shows fine
  • chr4 Sep 30, 2010
    it's a brand new printer and it's printing from a POS application (on a Mac, btw, not Windows). As far as I can tell, there is no way to reset it other than powering off and on again
    President:
  • 2,047 Answers
Although the print preview shows fine in most cases it is not totally fine. The problem can be caused by two things the first being the printer settings or the document settings. Try checking them and adjusting both settingappropriately.
If after doing this the document still prints that way put the printer of clean the unit and if possible run a quick service of the printer. Also uninstall the driver from your PC restart the PC and re-install it. This usually resets the printer automatically.
Hope this solution has been helpful?
Posted on Sep 30, 2010
  • Rockme
    Rockme Sep 30, 2010
    If it is new then check the settings. Can you locate the printer page orientation settings ? if you get this adjust the settings about .5 inches in both directions so your documents can be accomodated.
    Hope this solution is helpful?
Won't print from another mac as can't find printer
You can try going to System Preferences and pressing Resume to make sure the printers are not off line. Otherwise, please contact us (see dymo.com for numbers).
^CM
Dec 26, 2013 | Dymo LabelWriter 1752266 450 Twin Turbo...
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
Label writer 450 is only printing half a label and then the blue light flashes like it is out of paper. New roll, worked fine before it ran out
Make sure you use genuine DYMO labels, not compatible ones. Also, make sure you select the right size in DYMO Label.
Disconnect the USB cable and the power cable to reset the printer. Check if the roll is loaded properly - the holes between the labels have to be on the left. Connect the power cable. If the blue light is solid, connect the USB cable and try to print.
Check the DYMO Label version (Help > About). If it is below 8.5.0, you have to update it.
^CM
Feb 08, 2013 | Dymo ® LabelWriter® 450 Series PC...
Dymo\DLS8|printer Settings.xml access to the path is denied
Just remove PrinterSettings.xml and Settings.xml (in DataTracking folder). Next time you start the software it creates new files and the problem is gone.
Feb 04, 2012 | Dymo LabelWriter 450 Turbo USB Label...
Dymo 450 prints too many lables
You may have to disable bidirectional support: right-click the printer > Printer Properties > Ports > uncheck the option.
^CM
Nov 23, 2011 | Dymo ® LabelWriter® 450 Series PC...
When adding the Dymo labelwriter 450 turbo to Windows 7 machines, the installation completes fine. When attempting to print, an error shows up in the device manager that says Access Denied for the print...
i HAVE LABEL WRITER 450 TWIN TURBO AND I CAN NOT PRINT RETURN ADDRESS LABELS. i HAVE UNINSTALLED AND INSTALLED AGAIN THAT DOESN'T WORK THE RETURN ADDRESS LABEL IS THERE IT WON'T LET ME TYPE ANYTHING IN THE SPACE PROVIDED IT WAS WORKING FINE THEN THE NEXT DAY IT WAS NOT
THANK YOU
Aug 19, 2011 | Dymo LabelWriter Thermal Printer
My Dymo LabelWriter 400 is printing vertically. How do I change it to print horizontally? Thanks
Hi Kaylene, i`ve experience that before.. Just set the print set-up/ preview into horizontal.. The dialog box of print preview will show you the position of your text before printing Dymo Label! goodluck!!
Feb 07, 2011 | Dymo LabelWriter 400 Turbo Thermal Printer
With Dymo Labelwriter 450, Can labels be printed in WORD without going through Dymo V8 software? I can print in Word but labels come out in portrait format and not landscape
They can. You may want to use the Word add-in for this. Please contact our help desk for further information (see dymo.com for contacts).
^CM
Jan 21, 2011 | Dymo ® LabelWriter® 450 Series PC...
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
My dymo label writer twin turbo stopped printing on left side!
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. 4.) the print head is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view.
5.) The labels are defective - if you have another roll of the same size, try it to see if it has the same issue. If not, make sure you purchase quality labels like Dymo name brand or Labelvalue brand Dymo labels.
6.) The printer is defective. Labelwriter 400s have a 2 year warranty, so you can contact Dymo customer support to determine if the printer is defective and return to the retailer you purchased it from.
Oct 08, 2009 | Dymo LabelWriter Thermal Printer
Dymo LabelWriter 450 Turbo USB Label 1752265 Thermal Printer Logo
223 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
