Question about Amana 24 in. DWA22A Built-in Dishwasher
After my dishwasher fills with water, and starts to clean it doesn`t do anything but humm.
    Problem Solver:
  • 15 Answers
More than likely something is sticking in pump, remove access panel and reach into motor opening and try to turn motor over by hand if you can (using motor cooling fan blades) .This problem happens more often if machine is used seldom
Posted on Oct 01, 2010
Why doesn't our Whirlpool dishwasher clean anymore?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
May 17, 2011 | Whirlpool Dishwashers
OK, so if the dishes are not getting cleaned, particularly anything plastic, then what?
Is the water around 130 F, if so make sure you run the water at your sink till the line fills with hot water before starting the machine. Make sure your getting enough water and that the spray arms are turning and clean.
Nov 22, 2010 | LG LDF9810ST Built-in Dishwasher
Water won't pump
yes,,, it is the water fill valve,, when it started to go bad the noises where from the pump, then it got quite now it is gone,, make sure you turn off the water supply before removing the unit,, only reason I am saying this is that I have even seen plumbers not turn off the water supply because they don't have hater goning thru and forget that why they are taking it out lol
Feb 11, 2009 | KitchenAid 24 in. KUDP02FR Built-in...
Kitchenaid double-drawer dishwasher will not start
i just installed a used dishwasher. It filled up with water then stopped. The lights are still on as far as the cycles but nothing is happening. I did the factory diagnostic test and the service diagnostic test, not sure how long each test was supposed to take because after it seemed to go through each cycle by the lights on the front nothing else happened. I waited over 30minutes because I didn't know how long this was going to take. When all the lights on the front went out I tried to turn it on like to run a wash cycle and nothing is happening and the bottom is still full on water. HELP!!
Oct 24, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Amana 24 in. DWA22A Built-in Dishwasher Logo
154 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
