Question about Dishwashers
Will not run through a cycle. After it gets so far it will shut off and there is no power to the control panel. After a while the panel lights back up and you can start the cycle over but it shuts off again.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the Timer going bad and should be replaced. Also prior to replacing the Timer
check whether the drain is not clogged or blocked and the line is not kinked. If all this is fine and the pump is running then the timer may be at fault. Dishwashers timers can't be repaired, if yours is defective, replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 30, 2010
GE Quiet Power 3 won't start when door is closed.
What is the exact model number? This may be an issue with the cables that connect the door to the power supply.
Apr 06, 2018 | GE Dishwashers
Where to look from here?
It sound like the limit switch is shutting off and not coming back in to play .
Mar 14, 2017 | Heating & Cooling
We have replaced our control panel PN 99003139, THREE times. Each time same thing happens. The lights and buttons gradually and intermittently go out. The dish washer will still run, so long as the st
Whirlpool parts come with a one year warranty WP owns Jenn Air take it back I have replaced this panel then had to go back and change again in 3 days it failed yes could be a bad batch of panels the panel is powered by the control is the control taking out the panel can't say it is a computer maybe sending to high a voltage to panel no way to test that
Jan 30, 2015 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Elctrolux dishwasher won't start, display won't light. Any suggestions?
Good Morning Friend,
I understand your Electrolux dishwasher, model# EWDW6505GS, seems like it is not receiving power to the control panel. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and try any cycle. If you are still not receiving any lights, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing your control panel to not have power.. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
Dishwasher starts in any type of cycle, runs for a minute, then shuts off as the lights blink out.
in general your wash motor can cause that. It gets old and you can hear the wash motor making a rumbling noise when it turns on. The increased load with cause a thermal coupler to turn the unit off.
Jun 23, 2014 | GE Dishwashers
FGGS3045
Good Morning Ralph,
I understand that you were running the self-clean cycle on your Frigidaire range, model# FGGS3045, and it stopped and the control panel went dark. I also understand that there are no lights of any kind. I suggest that you give your appliance a hard reset by shutting the power off at your home's circuit breaker for 3-5 minutes. Once time has passed, restore power to your oven.
If you do receive power and the control panel and lights come on, you will have to reset the clock before doing anything else. You will reset the clock by pressing the "Set Clock" button. "CLO" will appear in the display area. You will then enter in the time and press the "Start" button. "CLO" will disappear and the time will show. Once you have reset the clock, try either turning your oven on a bake cycle or the self-clean cycle. If the same thing happens, to where the control panel goes dark and the lights go out, I suggest contacting your local authorized technician.
If you do not receive power, I suggest contacting your local authorized technician for assistance. They will be able to diagnose your range and determine why there are no lights coming on, as well as no power to the control panel, and if there is a temperature cutoff that might possibly be causing your range to not have power. Hope this is helpful.
-Best Regards-
WP
Mar 08, 2014 | Frigidaire 30" Slide-In Gas Range FGGS3045
Whirlpool Duet Front Loading Washer Won't Turn On
MY WASHER WAS DOING BASICALLY THE SAME THING. I HAVE A WHIRLPOOL FRONT LOADER MODEL #GHW9460PL0. MY HUBBY REMOVED THE 3 SCREWS FROM THE BACK OF THE WASHER, UNPLUG IT FIRST, AND TOOK THE TOP OFF. WE THEN CAREFULLY UNPLUG THE WIRES AND REPLUGGED THEM BACK IN 1 BY 1 SO U WONT GET THEM MIXED UP. WE THEN TRYED IT, AND THE CONTROL LOCKED LITE STAYED LIT. HE HELD THE SIGNAL CYCLE BUTTON IN FOR 3 SECONDS AND THE LIGHT WENT OUT. WE THEN TRYED RUNNING A CYCLE AND SO FAR SO GOOD!! GOOD LUCK!
May 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. Catriver...post back.
Aug 28, 2006 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
