Question about Cameras
I try to turn it on, it keeps focusing in and out and then says lens error and wont let me do anything.
    Brigadier General:
  • 3,006 Answers
Your camera has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the manufacturer's service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 30, 2010
I can't get rid of 'Lens Error' message and keep my camera switched on for more than a minute.
You don't need to drop a camera to get a lens error. Could be anything, from holding the camera in a wrong way (touching the lens barrel) or a bit of dust in the barrel or a gear, or a gear that breaks off. If the lens retracts correct when the camera is switched of, and comes out to the full extend when it is switched on, you should think everything is in working order. But when you say, the screen looks ver blurry that could be an indication, the lens is not coming out correct, or the focus mechanics does not work correct. I'm afraid you have to bring the camera in to a service centre (or buy a new one) if you can't solve this, by again take out the battery, charge the battery and reinsert the battery.
Jan 26, 2014 | Nikon COOLPIX S3300
My nikon coolpix s220 have a lens error and when i turn it onthe lens goes in and out like its trying to focus and it makes a wierd noise. it also wont let me do anything it just pops up saying lens error
Try removing the battery/batteries and clean the contacts underneath. Also, clean the battery contacts and the charger, if so equipt. To do this, dampen a cotton swab with rubbing alcohol and rub the contacts. Blow into the compartment after to clear any residue.Thanks, Dana
Jan 03, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
I own a casio exilim ex-z850. it has been showing a lens error, every time i try to take switch it on. the memory card is fine, i view the pictures. but the lens wont open up or anything. please reply...
This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Sep 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Focus error on camera wont take pictures wont put
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 12, 2010 | Fuji FinePix A500 Digital Camera
My camera wont focus/ the lens wont close when i turn it off
i think its seen better days it will be cheeper to dump it and buy a new one sorry!
Oct 20, 2009 | Cameras
Focus error show up and can't take any pictures
Had "FOCUS ERROR" appear on my Finepix S9500. The lens seemed to be stuck at the extremity of focus range. I resorted to hitting the camera on a table while turning it off (because this is when it sounded as though the focus motor was trying to move the lens back). Guess what? It worked!!!!!
Aug 11, 2008 | Cameras
Blurry picture nikon s200
It doesn't say lens error? but it won't focus? it is probably the same as the other people who do have lens error displayed on the screen, the lens is broken is what the repair company told me about my s200 when i told me lens error
Jul 22, 2008 | Nikon COOLPIX S200 Digital Camera
The lense won't go in
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 27, 2008 | Cameras
700x digital zoom mini dv - focus problems
Hi, its your ccd sensor. JVC are doing a free repair until June 2008. Visit their website for contact number and more information.
Dec 31, 2007 | JVC Everio GZ-MG37 Camcorder
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Cameras Logo
207 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
