Question about RCA HD52W59 HDTV Projection Television
Power When I try to cut my 52in on, the power button comes on and goes off 3 times.
    Genius:
  • 1,030 Answers
OK you have a rca itc222 chasis. THis set is notorus. i fix these everyday here at the shop. you have what is called a processor shut down. which means the main fuse is good and the processor is getting power. the main problem is that the processor off this set is shutting the set down due to 1 of about 25 different reasons. THe top causes include shorted high voltage components; HORIzontal output transistor. HIgh voltage splitter, Flyback transformer. Technicians have special computer interface equipment that read errors codes in processor. THe problem i have with these sets are if there too much wrong with them there not worth fixing... especailly if there are tube problems. average repair for this set is about 300 to 400. this set is 800 new at your local walmart. So if your a technician you can check some voltages,,,,CAReFully Television generate potentially lethal voltages and this set can hold 300 VOLTS UNPLUGED. Willie at fordtv.com
Posted on May 31, 2008
Rca 52" projection tv power button comes on and
Set has a 3 strikes rule built into it----tries 3 times to come on and if fails the set goes into shutdown.
Typical problems include: bad soldering on deflection board, bad parts on that board, bad high voltage transformer, and so on.
Jun 15, 2012 | Televison & Video
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
Got tv from friend want come on
Its over heating I have the same problem! the quickest fix is
to find away to get cold air blowing to back of TV. also move away
from any heat.
good luck
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I HAVE A RCA 52IN TV IT WANT COME ON. THE POWER BUTTON TURNS ON AND OFF THREE TIMES BUT NEVER POWERS ON
sounds like the flyback as thats the 3 error code, but to be positive please respond to this same post with the model number of your RCA, and I will be able to help you out with your problem.
Jul 05, 2008 | Televison & Video
My projection tv trys to come on but won't you push the button and the power on light comes on but goes off comes back on then goes back off 3 to 4 times then goes off for good started few days ago but if...
I need the model number of your set. And can you count exactly how many blinks the power light blinks when you press power? Please respond to this same post so all comunication will be available for each response.
Jun 26, 2008 | Televison & Video
RCA TV Will Not Power On - Powered Off Suddenly
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
Is there a reset button for 52in rca hd ready rear projection tv?
Most likely there was one or more marginal connections on the main board and moving the set has completely opened those connections. If you can solder, try resoldering any connections on the boards that appear to be grainy or have rings. Update this with the results. That may resolve the problem. If not, we'll look further into the set for component failures.
Dan
May 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52in HDTV will not stay on
I would turn the circuit board over and check for clod solder joints and cracked solder, you will have to look close, my other sugestion would be to get a can of freeze and spay the different IC's and see if it stays on longer.
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52in Projector
Most likely the issue in on the large signal board. The TV is going in to shutdown. Repair might run $200.00 or so.
Jun 08, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
