Question about Mitsubishi WS-55807 TV
I have a ws-55807. power light comes on then hear a click and goes dead. I pressed the menu and input and get the code 2 blinks pause, 2 blinks then repeat 4 times. Am I understanding right from what I have picked up on here that the secondary power supply is out? My question is what is a rough cost for someone to repair something like this?
  • safald Sep 30, 2010
    That is awesome news! I will get the repair kit and give it a go! Thank you so very much!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code 2-2 means short protect which is either caused by bad convergence ICs and/or 2 Pico fuses (F9A05 and F9A04). You'll need to open the back of the unit and replace the parts that have gone bad to resolve this issue. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 30, 2010
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Wont turn on, turn power on and tv turns off and you hear click.
DO THE SELF CHECK WHEN POWER LIGHT GOES OFF.
On front of set press and hold both the menu and input buttons for at least 5 seconds and release both, power light will blink a two digit error code like 2 blinks, 2 blinks, and pause and repeat several times.
Let me know error code and I will tell you what it means.
SD TECH
Dec 07, 2010 | Mitsubishi WS-55315 55" Rear Projection...
My mitsubishi television ws-55807 went out while watching it, what can i do to solve this problem?
If power light comes on and then goes off do the self check this set has:
when light goes off and front of set press and hold both the menu and Input (device) buttons in at same time for at least five seconds and release both buttons.
The set will (the power light) blink a two digit error code like, 2 blinks, 2 blinks, a pause and repeat the code several times.
2,2 is most common error code, let me know what error code if any you find and comment here and I will tell you what it means.
The self check is designed to narrow down where a problem is.
SD TECH
Dec 04, 2010 | Mitsubishi WS-55807 TV
TV won"t stay on turns off in 3 seconds WS 55807
Do the self check when power light goes off.
On front of set press and hold both the menu and input buttons for 5 seconds or longer and release both buttons.
Power light will blink a error code like: 2 blinks, 2 blinks, a pause and repeat about 4 more times.
If this information told you something rate this solution as very helpful as I do this here for free.
SD TECH
Aug 28, 2010 | Mitsubishi WS-55807 TV
I have a Mitsubishi hd 1080 tv and last night it stop working it wont turn on or off please help
IF POWER LIGHT COMES ON AND THEN GOES OFF:
DO THE SELF CHECK THIS SET HAS: ON THE FRONT OF THE SET PRESS AND HOLD BOTH INPUT AND MENU BUTTONS FOR AT LEAST 5 SECONDS AND RELEASE BOTH.
POWER LIGHT WILL BLINK A TWO DIGIT ERROR CODE LIKE: 2 blinks, 2 blinks, a pause and then it will repeat the code 4 more times.
Let me know if you get a blink code and I will tell you what it means.
If this information was helpful, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 17, 2010 | Mitsubishi WS-55807 TV
I have no picture or sound when i hit the power button it clicks off
Please do the self check this set has:
When the power light comes on and goes out press and hold both the MENU and Input (also called Device) buttons at the same time for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code--for example--2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means and what may actually be the problem.
I am here to help people.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 18, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Dec 05, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS-55909 dm board repair
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
No picture
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is.
Dec 05, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
451 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
