Question about Canon PowerShot A570 IS Digital Camera
All of my sd cards says locked how do i unlock them i tried to unlock the cards using the tab but i think its the camera
  • 567 Answers
Mostly, the card lock can be unlocked by sliding the lock switch to open position. You stated that you have already tried that.
In case the issue persists, it could mean the the write protect on this card was perhaps set by mistake while it was connected to the computer.
You will need to use the computer to cancel the read-only setting.
Please connect the card to your computer through the camera or a card reader and cancel the write protect on the card.
Right click on the card and go to properties and un-check the "Read Only" box.
This will take care of the issue.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this free solution.
Posted on Sep 30, 2010
2 Suggested Answers
  • 300 Answers
SOURCE: Hi, I have a PowerShotSD630...when
Elementary, Watson. Your SD600 isn't compatible with SDHC cards.
Posted on Jun 30, 2011
When we try to take a picture on our Vivatar Camera it says,card locked. Please help us with this problem.
Most likely your sd card is locked. Try removing the sd card and moving the small white tab on the side of the sd card from locked to unlocked and give it a try.
Lewis
May 15, 2011 | Vivitar ViviCam 5024 Digital Camera
Tip
How to Unlock SD Card
<p>Many times people do not realize that a <span style="font-weight: bold;">SD card</span> can be <span style="font-weight: bold;">write protected </span>or locked. They will <span style="font-weight: bold;">try to download pictures</span> or <span style="font-weight: bold;">make changes to the pictures </span>and the <span style="font-weight: bold;">SD card will not allow</span> them to do it. The little lock feature on the side of the card will <span style="font-weight: bold;">write protect the SD card</span> so that changes cannot be made. You will need to <span style="font-weight: bold;">unlock the SD card</span> to be able to make the changes that you want to make or download anything from it.<br /> <p><br /> <br /> <p><span style="font-weight: bold;">To allow the SD card to be accessed</span> is a simple as sliding a small tab on the side of the card to the <span style="font-weight: bold;">unlocked position</span>. Usually this means sliding the tab towards the back of the card and away from the front of the card. The card will have to be removed from the <span style="font-weight: bold;">camera</span> or <span style="font-weight: bold;">PC</span> to be able to do this.<br /> <p><br /> <br /> <p>Here is a <span style="font-weight: bold;">picture of an SD Card</span> and you can see the tab on the side of the card. It clearly shows you what is the locked and unlocked positions on the card.<br /> <p><br /> <br /> <p><img src="heatman101_2.jpg" /><br /> <br /> <p><br /> <br /> <p>This feature can be very useful to make sure that you do not inadvertently <span style="font-weight: bold;">erase data or pictures</span> from the card. If you have children viewing pictures on the SD Card make sure to lock it before allowing them to play around to make sure that they <span style="font-weight: bold;">do not erase your pictures</span>.<br /> <p><br /> <br /> <p>As you can see this is a very good feature to have and it will be very useful to you, but you do need to remember to unlock it before trying to make changes to the card.<br />
on Apr 21, 2011 | Cameras
My camera says CARD LOCKED. I cannot use it and have looked through the manual for help, but could find nothing.
Remove the memory card from the camera, look along the one edge for a tiny switch, slide it towards the contacts to unlock the card. The switch that is furthest from the contacts is in the lock position to avoid erasing the pictures, now! if the card is already in the unlock position slide it back and forth to reset, if that fails! the card should be replaced.
Mar 21, 2011 | Cameras
Even though the sd memory card is "not" in the locked position, it still says card locked when I turn my camera on. I have a Canon Powershot sd 780
Hello(Read the whole solution, i think you have the second scenario)
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Nov 27, 2010 | Canon PowerShot A530 Digital Camera
It says my card is locked
Hello
Kind regards
Andrea
Aug 16, 2010 | Canon Cameras
How do you format an sd memory card?
You should be able to use the camera's menu to format the SD card, just go into the setting menu to format it.
Also make sure the write protect lock is off on the SD card itself. To remove the write protect lock, take the memory card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab up to unlock it, it will be at the side of the card like this 59a6de4.jpg .
Regards.
Apr 12, 2010 | Fuji FinePix S7000 Digital Camera
SD card locked
The lock switch on the SD card looks like a bit of plastic without any electronics. A bit like the write-protect tab on a 3.5" FDD.
So there must be a sensor in the reader / camera which detects the position of the switch. Maybe there is dirt in the sensor. The best way to check would be to try another SD card, but you could try blowing out any possible dirt and see if that fixes the problem. Can the camera write to the SD card?
Try moving the switch to lock and unlock status.
Apr 07, 2010 | Canon PowerShot A75 Digital Camera
CANT WRITE TO UNLOCKED SD CARD I've tried repeatedly to write files to various sd memory cards in my ZS1 and it always gives me the message that the card is locked and can't be written. The cards are...
Are you sure that the lock / unlock tab isn't getting moved to the lock position when inserted AND then moved back to the unlock position when removed? Stranger things have happened.
Some cards have lock / unlock tabs that are so flimsy that it seems that you can "will" them to move. Try placing a small amount of tape in such a way that the tab is prevented from moving (if you never use the lock feature like me, you could use a drop of glue instead of tape). You might have to remove some excess tape in order to slip it back into the camera if the slot is "tight".
If still unable to write to the card in the camera, but can when in a card reader - the problem could be in the camera. The next logical step would be to try a different card. If the new card fails in the camera but not the card reader; the camera probably needs to be sent out for repair.
I hope this helps - and good luck!
Nov 13, 2009 | Panasonic DMC-ZS1 Digital Camera
Card Locked
If it is an SD memory card, there is a switch actually on the edge of the card. Try moving it to the other position and reinstall. Most people don't realise it's even there untill they have problems.
If this works , please rate accordingly so others may follow.
Thanks.
If it doesn't, there will be access to view the locked photo's on the camera. Selecting protect/ lock again should remove this.
Jul 09, 2008 | Canon PowerShot A550 Digital Camera
How do you get rid of card locked message on Polaroid T830?
SD cards have a tiny slide tab on the edge of the card.
This is used to lock the card, so you can't alter the contents.
Slide the tab to unlock the card.
Apr 04, 2008 | Polaroid i832 Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
