Question about Williams Heating & Cooling
I have a williams mod.#435fx-rnat heater, the vaent safty switch keeps shutting off the pilot i have continuity thru the switch, if i take the switch off the pilot lights the burnner
  • ron mitchell Sep 30, 2010
    i did check the flue plenty of draft and cleaned the unit. it's connected to the thermocouple could vent safety switch be bad?if i remove it runs fine
    President:
  • 2,777 Answers
It looks like your question got cut off here... you were saying if you take the switch off the pilot lights the burner...
I can't see what else you may have said in response to other experts, so please bear with me here and let me know!
Thanks Tim
Posted on Oct 01, 2010
  • 10,865 Answers
Hello. The most common problem with these units is dust and dirt. Use a small brush and a vacuum cleaner to thoroughly spruce up the entire mechanical area. J.
Posted on Sep 30, 2010
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Heat exchanger
If the fan coming on blows out the pilot light it is a pretty good indication that the heat exchanger is cracked. You should not continue to use the heater. I recommend contacting a qualified service technician to check it out and confirm that it is a cracked heat exchanger. Hope this helps
Dec 12, 2013 | Williams Heating & Cooling
Williams heater model 3509612
Hold the button for 30 seconds, then release. If it goes out right away, you have a bad thermocouple. If the unit does not sense that the pilot light is lit, all of the gas is shut off, including the pilot light.
Dec 19, 2012 | Williams Heating & Cooling
Pilot is lit,but heater will not turn on. was working fine yesterday.
this heater runs on 750 milivolts. it is created by the pilot lite. the heat for the flame on the pilot generator makes it all happen. the pilot should be covering the generator 3/8 to 1/2" from the top. the generator is about as big as you small finger. it has the wire going to it next to the pilot gas . a dirty or loose connection will keep it from working also. it connects to the gas valve with a red and white wire.turn your t stat as low as it will go and take a wire,paper clip?, and cross the red to the 3rd screw with out the white wire this should make the burner come on,bypassing the thermostat.if that works clean the wire connection at t stat
Jan 30, 2011 | Williams (5009622) Ceramic Gas Wall...
I have a williams heater 3508732 and the pilot keeps shutting off
I need to replace a furnace (Williams 3508732 Forsaire T-vent Type)
Is there a newer more compact one I can purchase?
What would you the best replacement if I didn't want the exact same one?
Dec 02, 2010 | Heating & Cooling
Pilot shuts off a williams wall unit thermostat is new is electronic and batteries are new and replaced constantly and pilot continues to shut off what is the problem?
You probably have a failing thermocouple. It is the small probe in the pilot light and you can get a replacement at any good hardware store or farm center.
Dec 28, 2009 | Williams Heating & Cooling
It can be shut off, but do not just blow it out.
Mar 02, 2009 | Williams 2509612 Ceramic Mid-Size Heater
How to start the pilot?
my heater will not turn on. William P322652 1 yrs old ? Iturn the heater switch on and the pilot ligth will not go on ?
Oct 07, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Williams Model 435FXR Serial GO222436 Forced air pilot keeps going out
BY THERMISTOR, ARE YOU MEANING THERMOCOUPLE, I.E. WHAT YOUR PILOT LIGHT IS HEATING? IF SO, COULD BE WEAK AND NOT GENERATING ENOUGH VOLTAGE TO STAY OPEN, SHOULD BE BETWEEN 10-25 MILLIVOLTS DC, WHICH CAN BE TESTED AT THE INTERRUPTER LEADS. YOU CAN ALSO BYPASS THE LIMIT DISC TEMPORARILY TO SEE IF THE UNIT STAYS LIT, REPLACE IT IF THE UNIT RUNS.
Jan 28, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Pilot light on but heater won't come on when I turn up the thermostat
Williams heaters have a manual reset for the spill safety switch. If the heater is not venting properly it will trip this switch and shut off main burner function. The switch is on the left side of the cover inside the small vent. You can use a screwdriver to push the button back in. If the heater then works you will need to get the vent inspected to make sure it is connected properly and there is no blockage.
Nov 26, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Heating & Cooling Logo
90 people viewed this question
Top Williams Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
