Question about 2K Games Joint Task Force for Windows
Have windows 7 and joint task force. won't install disc2. I GET THIS FEATURE TRANSFER ERROR FEATURE: DefaultFeature Component: Pak File: D:\data2.cab Error: Data Error (cyclic redundancy check).
4 Suggested Answers
SOURCE: Does Emperor RotMK work with Windows 7?
I have Windows 7 32bit and was able to successfully install Emperor ROTMK. I used to get that error with an old disk I had. it was because my disk was damaged.
Posted on Mar 13, 2010
SOURCE: im on windows 7 and
NOOOOOIT jtf op windows 7 spele!!!! ik had het ook eens gedaan,het werkte maar na een paar dagen kreeg ik blauw scherm en dat is het ergste wa een pc kan overkome op een paar dinge na. men geluid bleef ook hangen en men pc begon rare geluiden temaken zelfs met de workshop van jtf. op vista werkt de workshop maar het spel niet. je moet normaal dan de 'settings' veranderen maar da helpt niets bij mij
Posted on May 15, 2011
FTP Connection using Windows 7 64 bit
Individual applications that transfer files using FTP may have their own methods for monitoring transfer speed. But for a single method that works across all applications, consider an external bandwidth monitor. Windows no longer tracks bandwidth usage, but several free third-party tools display your upload and download speed. Close other Internet programs besides your FTP transfer tool, and check the bandwidth monitor to determine your transfer rate.
Net Speed Monitor
If your computer uses the 32-bit version of Windows 7, download Net Speed Monitor 2.5.4.0 for Windows. If your computer instead uses the 64-bit Windows 7 version, download Net Speed Monitor 2.5.4.0 for Windows (msi, x64). (See Link Below.) http://www.floriangilles.com/software/netspeedmonitor/download/ Run the installation program. The license agreement will open. Accept the agreement. Click "Next." Further options will open. Click "Next." Click "Install." A dialog box will ask whether you want your task bar to display the "NetSpeedMonitor toolbar." Click "Yes." Another dialog box will open. Click "Save." Run your FTP transfer. Check the transfer rate from the task bar. Bandwidth Meter b> Download the Bandwidth Meter installation program. (See Link Below.) http://www.bandwidth-meter.net/freedown.htm Run the program. Click "Next" through the options. Choose "Install" when the final step prompts you to. Run your FTP transfer. Check the transfer rate from the task bar. Hope this helps.
b>
Dec 17, 2012 | Esker TUN Plus 11.5 Upgrade Version for PC
Tip
Top 10 things to remember before installing WIN7
In this guide I will point out some important things that you need to do and remember before installing Windows 7 on your machine.
1 : Check the hardware requirement :- This is one of the most important factors that you need to keep in mind before thinking about Windows 7.Though Windows 7 should run fine with the 512 MB RAM system, it’s always better to follow Microsoft recommendations. Below are the Windows 7 requirements:
• A blank DVD
• A PC with a DVD burner
• A test PC for the Windows 7 Beta that meets these minimum hardware.
Recommendations (specific to the Beta and subject to change in the final version of Windows 7). Please do not use a PC you rely on for your work or daily use
• 1 GHz 32-bit or 64-bit processor
• 1 GB of system memory
• 16 GB of available disk space
• Support for DirectX 9 graphics with 128 MB memory (in order to enable Aero theme)
• DVD-R/W Drive
• Internet access (to download the Beta and get updates)
2 : Backup Vista :- If you are planning to upgrade from Vista SP1(SP1 is must) then it’s a good idea to backup your Vista drive so that you can revert back to Vista easily. I hope most of you know how to do back up task!
3 : You need to backup all your profiles and other important files that I have listed below. In case you are planning to wipe out Vista and install Windows 7 then also it’s better to create a backup of all profiles. Below are the important profiles that I backup:
• Documents
• Outlook pst file
• Windows live writer folder
• Saved games
• Other program profiles that you use.
4 : The most important thing for a web addict is browser bookmark folder. Use backup Bookmarks option in your browser to create a bookmark. Download Password Exporter add-on for Firefox to backup all your saved passwords. Also don’t forgot jot down all installed add-ons!
You can even use Mozilla Restorator to backup full Firefox profile.
5: If you have installed too many programs then it’s a good idea to generate list of installed application using a simple command that I have explained in the Generate list of installed applications guide.
6: Next obvious task is to backup all the custom settings that you have done to your Vista. Of course, you can back up! Type Windows Easy Transfer in Start Menu search box and hit enter to open. Follow the simple instructions to complete the task.
Windows Easy Transfer helps you move your files, folders, and program settings from one computer to another—all in one process.
Using Windows Easy Transfer, you can choose to move:
• User accounts
• Documents
• Music
• Pictures
• E–mail
• Internet favorites
• Program settings
7 : Move your Download folder from the “C” drive to any other safe location so that you will not lose the downloaded files.
8 : Though Microsoft recommends 16GB drive to install Windows 7 I recommend at least 30GB so that you won’t run out of free space in near feature.
9 : If you have any files in Desktop just move to safe place since most of us keep important files on Desktop for quick access.
10 : Last but least, don’t forget to retrieve Office and other product keys.
on May 11, 2010 | Computers & Internet
Dosn't work with windows 7
Broderbund's ClickArt 200,000 Image Pak should install quite easily on a 32-bit version of Windows 7.
64-bit version of Windows 7:
It is not possible to install ClickArt 200,000 Image Pak on a 64-bit version of Windows 7 - because the Setup.exe file is not compatible with any 64-bit Operating System. That is due to the fact that the Setup. exe file contains 16-programming code. 64-bit Operating Systems cannot handle any 16-bit programming code.
Hope this answers your query. Cheers!
May 03, 2011 | Broderbund Clickart 200,000 Image Pack for...
I can send my pictures threw yahoo mesanger but they cannot get my videos the error message is a porblem occurred while transferring the file "capture_20110215.wmv" transfer has stopped
1. Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. Thiswill bring up the Windows Security window. Click the "Task Manager"button and then click the "Task Manager" tab. 3. You will see a list offiles/applications. These are the applications running in the background onyour system, whether they show on your taskbar or not. Any one of theseapplications could be causing a conflict with the Yahoo! Messengerinstallation. 4. Click the top item on the list tohighlight it. Then hold the "Shift" key down and click the last itemon the list. This should highlight the whole list. 5.Click the "End Task" button. This will temporarily close allbackground applications on your system. 6. Click the "X" in the upperright corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should notexperience the same issue that you had before. 8. After Yahoo! Messenger is installed,runregistry cleaner reginout also rebootyour system. All other background applications will return to their originalconfigurations.
Feb 23, 2011 | Yahoo Messenger
Im on windows 7 and have joint task force, the game installed fine and i could play it fine for about a week, but then it came up with this message- Fatal error settings.ini(1): error: unknown...
Jan 08, 2011 | 2K Games Joint Task Force for Windows
Every time i try to install ooVoo this pops up: Feature:Defaultfeature, Component:Defaultcomponent, File: C:Program FilesooVoo,and error:Access is Denied.
it sounds like a permission issue:
1. are you logged in as an administrator?? if you're not try that first.
2. try to take ownership of the folder in question (some instructions on how to do that here)
3. also try to update and run antivirus and antispyware programs.
good luck
Jan 01, 2010 | Microsoft Windows Vista Home Premium...
Feature Transfer Error
Go into safe mode, edit the registry and remove all Panda entries. Also go into Configuration and uncheck Panda to startup if checked.
Try running the software while in safe mode and it gives a message that another software installation is detected and will be removed on startup, you'll know you need to find and remove files. It did not remove those mentioned above.
Feb 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Component transfer error
Download new drivers from your manufacturer. It sound like a corrupt file to me.
Feb 10, 2008 | Microsoft Windows XP Professional With...
2K Games Joint Task Force for Windows Logo
514 people viewed this question
Top 2K Games Video Game Consoles & Games Experts
Tony
Frank Zabroski
Frank Zabroski
Are you a 2K Games Video Game Console and Game Expert? Answer questions, earn points and help others
