Question about Pelonis WM-HO202C Oil Filled Radiator Heater
Four postion rotory switch broken. Where can I find a new switch or can I order one. The problem is turning the knob too far either breaking the knob or breaking the switch.
  • 3,083 Answers
I found these switches on the net:
http://www.partstore.com/SearchResults.aspx?q=poulan+switch&SearchTerm=True
Pelonis support might be able to get you a part number for the previous site, or they might be able to provide a replacement.
Good luck, and hope this helps:
http://www.pelonis.com/service_first.htm
Posted on Sep 30, 2010
Why ac will not turn off when car is driving down the road
Maybe your ac rotory switch. They are made of plastic and sometimes crack. Try pulling knob off to see if thats what happened. If so a new switch is pretty cheap to replace.
Apr 22, 2015 | 2011 Ford Expedition
How to turn off inside (dome light) in 1992 buick skylark
The headlight switch will either have a rotory knob that dims and brightens the instrument lights. When the instruments lights are at their brightest, just past that the dome light will come on. Back that off just a bit (you should feel it click). If it has no rotary knob then its in the pull switch that turns the headlights on. Twist that knob counter clockwise.
If that is not the issue then there may be a door jamb switch that needs adjusting.
Open a door and push on the door jamb switch (usually located near the front of the door area by the hinges). If it still does not go off then try another door until you find the one that makes it go off.
Then, with some pliers, grab the button and gently pull out. The button is inside of a sleeve and that sleeve moves in and out of the part that screws into the body. When you close the door it will push the button and sleeve in as far as it needs to go.
then if that is not it there is a wire for the dome light grounding. The interior lights have constant power and it is the ground that opens and closes to turn the light on and off.
Aug 24, 2011 | Buick Skylark Cars & Trucks
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
My 2006 Grand Caravan front interior light will not work when door opens, when the rotory switch is placed in the on postion or with the push button feature of the light itself. Occasionaly the light will...
The door switch is probably faulty, the pin is not moving in and out or stuck so no contact is being make.might have to replace switch or clean contacts on switch, Good luck!!
Feb 10, 2011 | 2006 Dodge Grand Caravan
How to change entry code
First, remove the control cylinder with your "DF59" control key. The cylinder unscrews to remove. Next, turn the knob all the way to the right, and release it.
Step three: Enter the existing code
Step four: Using either the spanner wrench that came with the lock, or a medium-sized flat-tip screwdriver, reach into the hole the control cylinder came out of; and turn the cam inside, about 1/4 turn (as far as it will go), and then back.
Step five: Turn the knob as far as it goes, ONLY ONCE, then release it.
Step six: Enter your new code.
Step seven: Turn the knob (this time, it should retract the latch).
Test it by turning the knob again: The latch should not retract. Now enter your new code and it should retract the latch as you turn the knob. If so, you have successfully changed the code.
Dec 23, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How do you light the pilot for the four burners on top?
This machine should have a ignition system when you turn the gas knob.
Make sure you have power to machine. if you do and you turn the know to the light postion and you dont here the clicking noise then it is posible you have a bad spark modual or switch harness or your ignition system is not geting power.
Sep 08, 2010 | Five Star TTN325-BGW Dual Fuel (Electric...
Fan blade barely rotates when turned on high.
there may be a problem with fan motor,but i believe your problem may be the rotory switch that controlls voltage to fan motor,to check this pull knobs off front ,then remove filter from back,there are 4 screws in bottom of case remove these,pull unit out carefully .there are 5 wires conected to unit ,two for fan 2 for on off switch,1 for ground just what wires go were,then disconnect wires from there posts,and pull unit out of box,find the two wires that go fan,snip wires that go to the circiut board leaving enough space to rewire after test get extention cord and snip off to make direct plug to fan to wall connect extention to the two wires from the fan motor and wire nut or tape so no short,pug extention cord into wall outlet if fan runs on a high rpm or max power,then your rotory switch is no good and you can install an external rotory switch on side of unit,if fan does not run any faster then your fan motor needs replaced,let me no if you need more help
Dec 03, 2009 | Ecoquest Living Air Classic Air Purifier
Black and Decker Spacemaker TROS1500 Timer Knob not available?? Checked several sites they say It has been discontinued. Are there any available any place????
The knob is available, I just recieved one I ordered online. www.partstore.com Part no. tros004. Cost approx. $14.00. Cheaper than a new toaster. Just turn the knob easy and too far!!!!!!!!! That is what breaks it.
Nov 13, 2009 | Black & Decker Toaster Ovens
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Pelonis WM-HO202C Oil Filled Radiator Heater Logo
1,088 people viewed this question
Top Pelonis Heating & Cooling Experts
paulcarew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
