Question about Maytag PYE2300AY Electric Dryer
Maytag DE 412
Our Maytag dryer heats just fine on Auto Dry/Permanent Press. It will not dry at all on Time Dry, although the timer itself works.
Any suggestions? Thanks!!! Our dryer has served us faithfully for many, many years, and I hate to give it up!!!
  • OuttaWack Jun 02, 2008
    Thanks so much! We're going to try this. Awesome advice!!
    Scholar:
  • 116 Answers
Does sound like the timer, although the clock is moving, the contact for the heater element is burned out inside the timer, you probably have used this timed dry for your normal day to day use and worn out the contact, new timer required.
Posted on Jun 01, 2008
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Kenmore elete model 110.67032600 timer changes to higher # and takes a long time to dry on auto dry.
I had this and it was lint trapped in door below lint filter screen.( several handfulls) Took door apart/ reassembled and he worked fine.
Oct 07, 2015 | Kenmore Dryers
Dryer ldg490 will dry on timer dry but runs forever on permapress (not much heat) what sensor is bad ?
sounds like bad timer points, they tend to burn and get stuck on some places ?
Oct 02, 2014 | Maytag Dryers
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Electric Kenmore Dryer 110.62622101 - Dryer will only work 'correctly' on timed dry. Auto dry will not time off and dryer gets super hot! Thermostats are replaced. I only use autodry - low heat. Using...
If timed drying is working the timer relay section is working fine but with the auto timer the thermostat must give the instructions to the timer unit to process and cut off accorrdingly. Since you have replaced the thermostat -- hope you made sure the thermostat was the same type- the fault is indicating to the timer unit by itself. The input of the thermocouple is faulty and is not reacting to the changes in temp to cutt off. You will need to replace the timer unit -- in fact many general use types of electronic temperature control units are available which can be used and can be coupled if the original unit is expensive. But try to check the thermostat input section. Good day
Aug 16, 2010 | Dryers
Dryer timer knob
This control could be the problem IF the blower wheel ain't stripped, the dryer is clean, and the duct work is free of air restrictions.It is located on the blower housing next to the fuse.ec8cbee.jpg
Mar 18, 2010 | Maytag PYE2300AY Electric Dryer
Maytag model# LDE482 electric dryer won't blow hot air
Either the control panel is defective or the dryer heating element is defective.
Jun 28, 2017 | Maytag Dryers
Maytag PYE2300AY Electric Dryer Logo
555 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
