Question about Nintendo Wii Console
I need a parental control reset code - Nintendo Wii Console
    Genius:
  • 1,456 Answers
Hi there
Click the "Wii" button located on the bottom left corner of the screen on the Wii Main menu.
Click the "Wii Settings" button on the System Settings screen. Look for the button with the wrench icon.
Move to the second page of the Wii System Settings screen by clicking the blue arrow.
Click the "Parental Controls" button on the second System Settings screen.
Click "I Forgot" when asked asked to enter your four-digit PIN.
Answer the secret question displayed on the screen. You provided the question when you set up your Wii. Note that the answer to the question is case sensitive.
If you answer correctly, you'll have access to the Parental Control Settings. Reset your PIN on this screen by entering a new PIN number and a new answer to the secret question, then clicking OK.
Click "I Forget" if you can't remember the answer to the question. Nintendo displays a message screen with text telling you to contact Nintendo customer support. At the bottom of the screen is a confirmation number.
Write down the confirmation number so you don't forget it, and leave your Wii turned on with the confirmation number screen displayed.
Call Wii customer support at 800-255-3700. Tell Nintendo customer support your confirmation number. You'll receive a master key code to reset your parental control PIN. Write down the master key code.
Return to your Wii, and click the "Enter Master Key" button. On the Master Key screen, enter the five-digit master key you received from Nintendo customer support, then click "Confirm Master Key." The Wii displays a message stating that "Parental Controls are Now Disabled." Click "OK" for the Wii to return you to page two of the Wii Systems Setting screen.
Click the "Parental Controls" button on the Wii System Settings screen. The Parental Controls screen will now show that you have no parental control settings enabled. Enter a new four-digit PIN number and secret question to reset your PIN, then click "OK."
Posted on Sep 30, 2010
I forgot my 3ds pin I need a master key
There is only one way to solve the solution and that is bye calling nitendo and the number should be located on the back of ur 3da and they will give u a inquiry code i mean thell give u a pjn u type it in and it resets ur parental settings
Nov 16, 2012 | Video Game Consoles & Games
Rest password
Go into the settings menu, Parental controls, reset parental controls. Click through the confirmation screens, and then it will give you a confirmation code and ask you to call Nintendo.
Instead of calling Nintendo, go to http://wii.marcansoft.com/parental.wsgi and enter the code. Even though it was originally written for the Wii, marcan's reset code generator will give you a valid code that you can enter into your DSi to remove the parental control.
Dec 10, 2011 | Nintendo DSi XL Burgundy
How do i unlock parental control, if i forgot my pin
Instead of calling Nintendo, go to this form and enter the code. Even though it was originally written for the Wii, marcan's reset code generator will give you a valid code that you can enter into your DSi to remove the parental control.
Jul 17, 2011 | Nintendo DS Lite
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
I need to get the universal code to unblock the parental block
There is no universal code, but there is a way to reset it.
Here is the procedure to reset the parental lock code:
Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
When the screen asks for the code, press the SELECT button, then enter in the code "7444".
The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
Oct 03, 2009 | Sony PlayStation 2 (PS2) Console
Reset Parental Control
There you go:
1) Hit [MENU]. Press [CH up / down] to select ?V-CHIP SET UP?, then hit [VOL up].
2) Enter 4-digit access code with the Number buttons. If you have not set up your personal access code, enter 0000 (default access code).
Jan 09, 2009 | Emerson EWF2004 20" TV
How do you reset forgotten parental control password?
for the phillips and magnavox tv sets the code is 0711, then open the menu setting restet the code to something easy to remember , or what i would do is completly disable the child lock by going to that option in parental settings.try it hope it works!
Apr 14, 2008 | Philips Magnavox 27MS343S 27" TV
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
Nov 29, 2007 | JVC AV-36260 TV
Parental control is stuck
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Oct 03, 2006 | Daewoo DTQ-19V1FC 19" TV
Nintendo Wii Console Logo
691 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
