Question about Mitsubishi WS-55859 55" Rear Projection Television
Screen is distorted smaller in the middle and large on the outside
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue is with the failed convergence (STK) ICs which needs to be replaced. It's not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you'll have to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime.
Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 30, 2010
My KV-SZ29M50 SONY WEGA TRINITRON FLAT SCREEN DOES NOT OPEN WIDE SIDE IMAGE BUT ONLY IN MIDDLE & IT HAS OUTSIDE CURVED SCREEN.WHAT IS THE PROBLEM WITH IT?
Pin cushion distortion. It is a fault with its circuit board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 27, 2016 | Sony Televison & Video
Tip
Wide screen monitor distortion Depending upon the screen resolution that has...
Depending upon the screen resolution that has been set in Display, the image will be distorted on these large wide screen monitors.
To correct this distortion.
1. Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
2. Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle.
3. When you are satisfied then click apply.
on Feb 24, 2011 | Computers & Internet
Wide screen stretches all my photos
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Dec 09, 2011 | Samsung Computers & Internet
Large monitor has distorted display
try adjusting your system resolution to a largest one (as 1280 x 800), or using a DVI cable, if your monitor and video card supports it.
Jul 12, 2009 | Acer Computers & Internet
I have a Mitsubishi 65819 and the image is beginning to distort, The image is warping so that the leading and trailing edges of the image are smaller than in the middle. There is also misalignment of the...
I am new to this fixya thing, but I have been working on televisions for over 20 years. So please let me know if you have any questions about the advice that I give.
If you can solder, solder the convergence IC's they are the big black IC's that are bolted to large heat sinks. I have found small ring cracks on the legs of the IC's. In some cases the legs of the IC's can separate from the IC's. But, overall I would say that this is an intermediate repair, and can be done by someone with a good soldering iron ~45 watts and some patience.
Apr 29, 2009 | Televison & Video
When a large picture is on the screen, it's distorted, blurry, and sort of stretched(hard to describe). But wording and smaller items look fine. I was told to try downloading an updated driver for...
livasinfw,,
its not in the driver..
its how the resolution of ur device to capture ur pictures..
and its in the pixels too..
other one is ur video card..
coz lower memory video card,,the lower the resolution of ur pix..
Apr 05, 2008 | Computers & Internet
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Dvd playback
Maybe it's something with picture settings, i.e. NTSC/PAL or INTERLACE/PROGRESSIVE SCAN.
Oct 07, 2007 | Bose 3·2·1 Entertainment System...
Mitsubishi WS-55859 55" Rear Projection Television Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
