Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Dishwasher model# FGHD2433KBI. washer was purchesed mid July, used 4 times. I just put in some dirty dish's and closed the door. A couple minutes later the washer turned on. No lights were on. After a few minutes I pushed the cancel button. Nothing happened. I opened the door and it sounded like a sucking sound and the pump stopped. No water in unit. I closed the door it started again. I cut the power at the circut box. Waited a few minutes and turned power back on. Power failure light came on. I pushed the cancel button and add soap ligh came on as it is usually lit when not in use. I opened door and closed it. The machine started running again. It sounds like the pump is trying to discharge water that is not in unit. No lights are lit when its runs like this and none of the buttons operate.
  • 409 Answers
SOURCE: More info on my dishwasher will not start
hi there,
thanks for the info. you are correct it's the touchpad. you can get one at www.reliableparts.com
let me know if can be of more help.
Posted on Sep 28, 2008
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
localwonder
  • 6784 Answers
SOURCE: Frigidaire dishwasher model FDB857RJS1 not pumping
HI, under the sump housing, there is a major issue concerning the circulation motor. there is a wash impeller that is connected to the circulation motor, via drive shaft and stud. this assembly has been stripped, due to a possible jam that was caused by a foreign object. the impeller is basically, producing the grinding sound you are hearing, you will need to replace this damaged wash impeller asap. it will ruin the motor soon if it is not removed.
This wash impeller is responsible for the flow of water during the wash cycle. it is not completely off the shaft but, eventually , it will break off soon, causing major damage to the circulation motor.
Posted on Jun 18, 2009
  • 323 Answers
SOURCE: Water not spraying
probably an air pocket blew the spinner sprayer off reattach and try again
Posted on Jul 04, 2009
  • 121 Answers
SOURCE: Our PLD4375RFC2 dishwasher fills up with water but doesn't run
no their is no fuse. sound to me like your motor is not working, however
the pump should still drain out.push cancel only and unit should drain if it does then id say motor bad. you can try to take apart and check motor blade ive seen toothpics, food , other objects hold motor impeller from turning making it seem like its the motor but actually its just stuck..remove btm wash arm and filter cover thentake two or 3 small screws from a plastic cover covering motor impeller, look to see if anything is in their if so remove. warning if you see a white ball down their leave it alone reinstall and see what happens. hope this helps.
Posted on Sep 17, 2009
How much salt goes in dish washer
You don't put salt in a dishwasher unless you want to ruin it.
2. You ONLY use a detergent specifically for dishwasher use as the cleaning agent and you 3/4 fill the soap dispenser in the washer (normally fitted into the door on the inside) with the dishwasher powder.
3. If there is a separate small compartment in your dish washer for a "rinse aid" solution to be used, you can use a rinse aid product designed for dishwasher use only. If there is no rinse aid compartment (this is also normally fitted to the inside of the door - if fitted on your machine) then you cannot use a rinse aid in your washer.
4. Don't use any other product in the dish washer.
Jan 30, 2016 | Dishwashers
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
Indesit Dishwasher not washing properly or draining
Could be a few problems here. The main one may be the timer. Generally the timer will tell each part to do what it needs to do and when, if it is not closing relays then you get a dishwasher full of dirty dishes. I would also check the pump to make sure it is operating properly. But I would venture a guess at the timer being the main problem.
Sep 06, 2012 | Dishwashers
Dishs have soap flim
If your dishwasher has been in use for a period of time, you may need to clean the interior of the washer.
The next time you are at the grocery store, pick up (2) containers of "Tang" orange drink. With no dishes in the dish washer, fill the soap container with Tang, close the lid and poor the remaining Tang in the bottom of the dishwasher.
Close the door and run through your regular wash cycle. You may have to repeat this with the second container if it is an older model washer.
The citric acid in the Tang will clean the soap scum off the inside as well as the pump chamber inside the washer.
Good luck, it worked for me, cleaned it nice and shinny and smells good too.
Regards,
Aug 13, 2009 | Dishwashers
Dishwasher was opened to add dish and would not start back
give it a few minutes it may have a built in delay when cycle is interuptede
Jun 01, 2009 | Dishwashers
Whirlpool quietpartner I Dishwasher wont clean anymore.
you need to take the blades that spin out and clean them off they have grime on them, is there water still in the bottom of the dishwasher when done> if so there is a plastic grate in the bottom rear of the dishwasher you need a 1/4 inch nut driver take the cover off and clean the debris out, there is a small stainless steele cutting blade in there be careful, it is to cut up foods that might not be washed off before putting dishes in the washer, also it is pressure that makes the detergent door open make sure you are getting full pressure comming into the waher, if non of this works the pump should be replace or it;s new dishwasher time
May 30, 2009 | Dishwashers
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
DIshwasher Cycle TIme INcreases by 20 minutes over two years
Try cutting the breaker off for 5 min, This will reset the control. The issue is in order for a dishwasher to clean the dishes properly the water in the dishwasher needs to be at least 120 deg f. If its not the dishwasher keeps adding more time with the heater on to try to achieve this temp. The dishwasher only uses about 1 gallon of water per fill so if the water heater is a ways away or the temp is not hot enough, the water temp in the dishwasher will not reach 120.
Jun 11, 2008 | GE Profile PDW8400J Built-in Dishwasher
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
82 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
