Question about RC 1/16 Tauch Panzer Iii Radio Control Rc Airsoft Tank
I Have an Exceed-RC 72mhz 6 channel PCM Transmitter and the RX-603 Receiver (for Helicopter). I fly planes and want to use this transmitter. i am having trouble finding a manual for this Transmitter for one, and second i need to know what brands of receivers would be compatible with the Exceed series PCM TX's, they are made by Walkera. I am having trouble finding compatible Receiver info and a manual!! HELP PLEASE!!!
SOURCE: Just got plane (Super Cub) and flew twice with a
356387029554350
Posted on Sep 15, 2009
  • 7 Answers
SOURCE: how do i fly my spin master air hog rc helicopter
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Posted on Feb 15, 2010
micromend
  • 748 Answers
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
Posted on May 13, 2010
  • 4 Answers
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
Posted on Sep 08, 2010
SOURCE: my rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
Posted on Dec 05, 2010
Rc helicopter loses connection
Check the transmitter crystal (if it has one) and check the wires in the heli's receiver unit.
You should turn heli on wait 3-secs then turn transmitter on.
Dec 26, 2013 | Toys
Why wont my RC helicopter respond to the controller
The Helicopter channel/frequency may need changing to match the channel/frequency on the transmitter.
OR change the transmitter channel/frequency to suit the helicopter.
Feb 06, 2013 | Toys
Just got a s301g Helicopter and it won't start up
Check the wiring where you plug in the charger to the helicopter. There is a red wire with quick disconnects. If its loose (the quick disconnect) you get this problem. In my case the helicopter came out of the box with this completely disconnected. It was hard to connect because there wasn't enough slack wire but once we did it the white light on the front of the helicopter came on and we were flying.
Nov 19, 2012 | Syma S301g Rc Helicopter 18" 3 Channel Rtf...
Have a Spectrum transmitter and AR6000 receiver. Cannot bind in a plane. Motor will run; but neither rudder nor elevater will work. Tried 2 receivers.
its been a while since my rc days but did all the servos operate properly before you installed them in the plane and are they compatible with the receiver also check that you have compatible channels on tx and rx hope this is helpful and i,m not trying to teach you how to **** eggs lol
bob
Aug 08, 2011 | Spektrum Toys
Where doI find the slot to recharge my helicopter
with most rc helicopters you have to disconnect the receiver unit from its battery and connect the charging lead to the battery lead the charger should have 2 leads 1 for the transmitter & 1 for the receiver
hope this helps
Aug 08, 2011 | xheli Exceed RC 24Ghz WarHawk 300 4Channel...
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
I bought 3 of the Syma S107 RC Heli's because it said the remote had 3 different channels. I see the Channel a,b,c on the transmitter but I don't see how I assign different channels to the 3 heli's and...
For one thing, there are only two channels. Although the transmitter shows a,b,c the switch has only two positions. The way to assign a channel to a heli is to turn it on and then simply operate the transmitter. The heli will lock itself onto the first frequency it receives, and start working. Before turning on the second heli, make the first transmitter is OFF, and set the second transmitter to the other channel. Turn on the second heli and simply operate the transmitter. The heli will lock itself onto the second transmitter's frequency, and start working. Then you can turn the first transmitter back on.
Oct 31, 2010 | SYMA Toys industrial New Syma S107 Mini...
Cant get the transmitter to match the plane
Hi
Somewhere on the transmitter is the transmitted frequency. If a hobby grade unit the frequency will start with 72.xxx mhz. If this is a toy store unit the frequency will start will 27.xxxmhz. Each of these bands will be subdivided into channels. At any rate, the receiver must match the frequency on the transmitter.
Aug 18, 2010 | RC Toys
Hi ihave brought helicopter ftw 730 but the remote control was not its own .the helicopter ftw 730 remote control frequency is 40 mhz but the one i have is 27 mhz so how can i make as 40 mhz remote...
Unfortunately you can't. You will need to change the receiver or the transmitter so they are both the same frequency range eg 40mhz or 27mhz. Then you will need to check the crystal is the same frequency for the Transmitter and receiver eg 40.25mhz. NB. you can't put a 27mhz crystal into a 40mhz set or vise versa it won't work.
Aug 21, 2009 | RC Remote Control Rc Mini Helicopter
Throttle goes wide open
Its is probably a faulty potentiometer in the transmitter's throttle channel. Take it back to the store if possible otherwise see if you can get another transmitter and bind it to your helicopter. The binding process will be in your instruction book.
Feb 28, 2009 | Esky Flight Simulator R/c Helicopter Kit
RC 1/16 Tauch Panzer Iii Radio Control Rc Airsoft Tank Logo
172 people viewed this question
Top RC Toys Experts
LP
Tom Chichester
Kevin K.
Are you a RC Toy Expert? Answer questions, earn points and help others
