Question about Frigidaire Dryers
How do you replace the fuse when your dryer tumbles but does not heat? it is a front load frigidare affinity electric dryer model LEQ700SE0
  • seguintheo Sep 28, 2008
    I have the same problem except frigidaire dryers have two internal fuses but are not shown on the installation or trouble shooting pages of their manual. Where does one find these dryer fuses and not the in-house fuses at the breaker panel?
  • 525 Answers
The fuses or breaker is located in your homes fusebox. An electric dryer requires 240 volts and 2-30amp fuses, or 1-30amp breaker. Locate your fusebox and determine if you have fuses or breakers. If fuses, then I recommend changing both 30 amp fuses to eliminate any possibility of being wrong. If it uses a breaker,(If not labled, look for the number 30 on a breaker). Flip the breaker to the OFF position, then back to the ON position. Repeat this action if there are more than 1-30 amp breakers and your dryer still doesn't heat.
Posted on May 26, 2008
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidare affinity stactable front loading dryer. runs for 10 to 15 seconds then shuts off. plenty of exhaust air. it has heat inside. tried resetting to factory specs but still have the same problem
Good Morning Percy, thank you for your inquiry!
From the information you have provided you Frigidaire dryer runs for 10 to 15 seconds and then will shut off. It sounds like it could be a possible problem with your thermostat or control panel. A reset may help with any internal miscommunications inside of your dryer. You can reset your dryer by disconnecting power from it for at least ten minutes. If that does not help your issue I would recommend having a professional technician out to perform an accurate diagnosis on your dryer to avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Aug 12, 2015 | Frigidaire Affinity Series Stackable...
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Model LEQ6000ES Affinity Frigidaire electric dyer purchased 5-29-06: tumbles but won't heat. Cleaned all air ducts and lint trap and still won't heat. Error codes not obvious. What else can we check?
you will need to check the main power and make sure there is 220 volts at the termianl block if that is goor then you will need to check the heating element an all thermal fuses.
remove the small panel in the back of the dryer so you can get the belt loose.
then remove the lid.Take out the four screws that hold the control panel in place.
then remove the screws that hold the front panel on and then remove the drum lift up on the back of the drum to get it loos e from the carrier bearing holder thenyou can get to the heating element and thermal fuse on the back wall of the dryer and the side wall of the heating element can.
Jan 08, 2011 | Frigidaire Electric Dryer
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jan 08, 2009 | Frigidaire Dryers
No heat
Check your breaker box, or fuses. A dryer will run but not heat if one fuse is bad.
Sep 28, 2008 | Frigidaire FEQ1442ES Electric Dryer
Dryers Logo
402 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
