Question about Peg Perego John Deere Farm Tractor and Trailer
On a John Deere Power pull tractor, it quit running. I have replaced the battery and the accelerator switch but it still does not run. What should I check next. Does it have any fuses that I cannot see ?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
There is a thermal fuse under where the steering wheel is, you can jumper a wire temporarily across there to see if thats where the problem is
Posted on May 22, 2012
2 Suggested Answers
  • 156 Answers
SOURCE: John Deere Gator not responding with new battery.
I upgraded my Peg Perego shifter and it came with the wiring harness.
I bought it at http://www.shopjandl.com/
Hope this helps.
Posted on Jun 23, 2009
John Deere L120 wiring diagram
The electric clutch draws current while engaged. It is quite hungry on power which means that if the battery is low, the generator may not be making enough to charge the battery and hold the clutch in too. This is why the batteries on these machines are so large relative to say an ATV battery. I have several times experienced units with low batteries which started the engine OK but would not hold the clutch in. The battery may be getting old and not holding the charge. Try charging with a mains operated charger. Make sure to check water level in battery cells. Running them dry can ruin the battery.
Aug 01, 2014 | John Deere L100 Series
I paid for an answer and have not received one order # 318683 John Deere 110 tractor 1972. tractor started quitting under load but would start then run fine. Tractor quit while mowing and I found 2...
There should be a switch in the clutch pedal area. Usually safety starts for tractors is that your clutch needs to be depressed to start engine and you need to be seated to turn blades. Good Luck....
Aug 31, 2011 | John Deere Garden
John Deere LT 133 lawn tractor quits running after about 10 minutes.
Will it restart right away or does it have to cool down? If it has to cool down, then run it until it quits. Next remove the plug, reattach the plug wire, and ground the plug to the block. Finally try to start it with the key. If you get no spark or very weak spark then the ignition coil needs to be replaced.
Let me know how it goes.
Aug 18, 2011 | John Deere Garden
My John Deere lawn tractor starts and runs ok but sputters and quit after usinng a short time and then is hard to restart. Putting gas directly into the carburator and it starts right away.
If you have a fuel solenoid switch on the float bowl you can remove it and replace it with a plug. You can leave the plug disconnected. Did it to mine and it runs better than ever. I think the solenoid get s hot and shuts off the fuel
Jul 31, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Won't start John Deere 310D Rubber tire backhoe
If you can test the alternator after it has run for 2 hours that would be helpful,if it is quiting after it gets hot then it likely need the stator replaced in the alternator.If this is not the case,then you need to either replace the park lock solenod valve or the instrument cluster is overheating a transistor and failing,this will cause the safety interlock circut to engage.Also the operator pressence switch may need to be relocated if the operator is less then 150lbs.Let me know how you make out,thanks.
Apr 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere 850 compact
There is a switch under the seat. Just to test and not to run, you can take a jumper cable and go around the switch. If you find this works, go get a new swtich. It is very important for safety...Good luck...Lee
Sep 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Peg perego john deere powerpull tractor will not run
could be the gears hold unit of gound and push pedal try to hold wheel if it stops gears are worn..best way to test it id say would be by pass switches 1 at a time let it run see if it does same thing if it dont theres your problem
Jun 22, 2009 | Peg Perego John Deere Utility Tractor
Peg Perego John Deere Farm Tractor and Trailer Logo
218 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
