My 1991 shogun was running realy well, i turned off the ignition while i was filling it up at the gas station. then when i went to start it up again it would'nt, i still have power to the radio an lights so am convinced its not a battery problem. can you offer me any other solutions?
    President:
  • 2,571 Answers
Not here, you need to post this in the right section, this is the barcode scanner / pc forum
Posted on Sep 30, 2010
Filled up with gas then later hardly cranks n bairly goes once gotten started
Same thing happened to me. I had to use a moisture removal product added to the gas. I used something from STP, but there are quite a few different types on the shelf. It worked very well. I keep some w/ me now & never purchased gas from that gas station again.
Jan 12, 2014 | 1991 Geo Tracker
Ran out of fuel put some fuel in gas tank but still wont start
Try removing fuel filter, empty it and clean, try again, sometimes loose particals from bottom of tank may be picked up when ran dry
Jan 28, 2013 | 1991 Ford F150
1991 Ford e350 Class C RV stalling out while driving, starts up again after 40 minutes fine. Any ideas?
The first thing you must do is check the engine control system for fault codes. To do that go here and read instructions.
Oct 26, 2012 | 1991 Ford Econoline
Will not start
make sure your plug caps are on securly,and if you have nothing on secondary side of coils their proably need to be replaced
Jul 28, 2009 | 2000 Honda VT 1100 C3 Shadow Aero
1991 Grand Am 2.5 L not starting
If it's turning over the starter doesn't sound like your problem.
When running a fuel injected car out of fuel you run the risk of take sediment { particles } flowing to both the filter to create a clog or the injectors to clog them.
Be a bit more specific does the car crank or crank and just doesn't start
Jul 27, 2009 | 1991 Pontiac Grand Am
1991 240 gl not starting.
Sounds like a starter problem. Check that the connections at battery and starter are secure and free of corrotion. You can also try tapping on the starter while the ignition swith is being turned to the start position. If that works replace starter. The stalling can be caused by a number of problems: idle too low, fuel pump pressure to low, air mass and or oxygen sensor malfuctioning. A process of elimination.
Jun 04, 2009 | 1991 Volvo 240
I have a 2000 Honda CRV, and this morning I went to the gas station to fill up, my car was running fine all the way there, and I let it run while pumping gas, I went in and paid came out and my car was no...
shoot some ether into your air intake hose a few times. i agree it sounds like you got water in gas. ive had the same problem twice over the years and this worked for me
hope2help shack
Mar 25, 2009 | 2000 Honda CR-V
Truck doesn't start
there is a bleeder on the gas rail bleed some out on a rag and see if it was gas you filled up with or water i have run in to gas stations not fixing cracked tanks and as you know water floats on gas.start rag on fire gas is good if it doesnt light than you need to hurt someone heehe. ok now if your gas is good then the next step is to turn your ignition key on but not try to start and listen to see if you can here the fuel pump kicken in if not there is your problem is so then you need to replace your fuel line filter. good luck.
Nov 16, 2008 | 1991 Chevrolet K1500
Turned vehicle off and filled with gas. would not restart. engine turns over fine and was running fine whe turned off. Just turned 61,000 miles. 1992 model.
sounds like its your fuel pump went out. sometimes when you fill it with gas at a gas station it goes out. you should try a fuel pump
Oct 31, 2008 | Mitsubishi Montero Cars & Trucks
Computers & Internet Logo
David Payne
David Payne
