Hi where is the filter for a hotpoint WT960 washing machine
Hi there please could you tell me where i would find the filter on a hotpoint WT960 please?
  • blakewayw Jun 24, 2008
    i have a F -12 fault notice anyone any ideas
  • Anonymous Mar 23, 2014
  • 868 Answers
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
Posted on May 26, 2008
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Nov 20, 2014 | Hotpoint Washing Machines
My hotpoint WT960 stopped filling and displayed F10 error please help
'F10' for Indesit (Hotpoint, Ariston) decodes as 'pressure switch, check PS, wiring and module' which sounds major BUT is not uncommon in this make of machine and is often caused by poor contact between plugs/ cables and the control PC, just needing re-seating- by an engineer ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 28, 2011 | Hotpoint Washing Machines
Hotpoint WT960 has the H2o symbol flashing it has water and no pipe kinks
Make sure that the water pressure is o/k, and that the valve is fully turned on.
Also check the filter in the inlet valve, you wilave to remove hose to do this.
Mar 29, 2010 | Hotpoint Washing Machines
Hotpoint wt960 keeps stopping and displays F-08, any ideas, Thanks
  1. F08 is a sticking heater relay.
  2. Check connections on pressure switch
  3. Check heater connections.
  4. Check module connections.
  5. Check pump filter is clear.
Please rate my solution.
Nov 16, 2009 | Washing Machines
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Removal of the filter from a hotpoint wt960
Filter is located inside large black hose at rear of washer, remove lower rear panel and remove hose, and clean plastic filter inside hose.
Mar 31, 2009 | Washing Machines
Hotpoint ultima wt960
F10 means that the water level switch is not sensing the correct water level, this can be caused by faulty switch, a blockage in the pressure system, a blocked drain pump or filter.
It is a process of elimination I'm afraid.
Please rate my suggestions to solve your problem.Thanks.
Mar 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Filter on WT960
hi, in the uk the filter is behind a flap on the bottom/front of the machine, be careful as when you undo it some water will leak out, hope this helps
Feb 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wt960 lcd screen failure
Hi, I have experienced this problem on several hotpoint machines with led display's. There is really only one solution for it! If there are no wires hanging off then the answer is in the board, And you will need to replace it. It is a non servicable part and cost around £40.00+++.
Good luck.....
Dec 24, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
1,830 people viewed this question
Top Washing Machines Experts
