Question about Panasonic SC-HT820V System
Panasonic home theater sc-ht820
After i turn off ht it automatically turns on again about 30sec's later and keeps repeating this senario until i plug plug
SOURCE: Panasonic home theater
Okay, that guy is soooo wrong. Do you have your remote? Click setup and click disc and click on ratings and click unlock, just click #8, you may have to do this twice but it will unlock... no taking this apart... good luck :)
Posted on Jan 01, 2008
  • 4102 Answers
SOURCE: unlock panasonic sc-rt 50 home theater
hi what code do you need is it the region unlock code or code because the device is locked i need more info before i can assist you further ok
Posted on Mar 18, 2008
  • 3422 Answers
SOURCE: unlock a panasonic dvd home theater to region 2
You can buy the codes from HERE or HERE
Goodluck..
Posted on Mar 19, 2008
SOURCE: Panasonic SC-HT75 Home Theater system
with the unit switched on press and hold the stop button and press the power button once. if that doesn't work then try it with the play button.
Posted on Jun 12, 2008
appman67
  • 33 Answers
SOURCE: panasonic home theater sa-ht920
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Posted on Sep 21, 2008
Turn off timer on home theater system
You can turn on or turn off the home theater's sleep feature by pressing and holding the [-SLEEP] button then repeatedly pressing the [-SLEEP] button.
Jun 22, 2014 | Panasonic Sa-btt270 Receiver For...
My SC BT100 is perfect until I use the IPOD dock, it works ok for 10mins but then 'blows'. the unit becomes very hot and wont turn back on until it has cooled down.
You are overpowering the Amplifier and it is protecting itself until it cools down.
The reason for this is that the output from the IPOD is already pre-amplified. If it didn't shut down you would either blow the Amplifier or Speakers.
If you keep the volume turned down to a minimum on your IPOD and use the volume control on your theater system you should be OK but still don't turn the theater system to full output.
Please leave feedback.
Cheers
Andy
May 02, 2011 | Panasonic SC-BT100 Theater System
Can I connect a Sony DVD Player DVP-SR90 to the Panasonic Home Theatre SC-HT75 to achieve surround sound without direct SCART connection - and how?
You can connect your Sony DVD player to your Panasonic HT using an analog RCA audio cable (white and red) for stereo sound. Connect to the AUX inputs on the HT and select AUX. Since the Sony DVD player only has SCART, you would need an adapter, scart to RCA. Like this one:
http://www.maplin.co.uk/scart-to-3-phono-plugs-with-in-out-switch-28102
Check for compatibility. Use the red and black RCA plugs for the audio into the HT.
Your Panasonic HT does not have a digital audio input which would be required for multi-channel surround sound (Dolby Digital 5.1)
Mar 14, 2011 | Panasonic SC-HT75 System
Need Vizio TV code for my Samsung HT-X50 home theater remote!
Mine is 5. Press the TV button and let it go. When it quits glowing press the power button and hold it down. Then press a number (1-86) on the keypad while holding the power button down. If the TV turns off, you are done. Press the power button again and the tv should come on. If it does not work. Release the power button for a second and then repeat with a different number until the tv turns off.
Jul 05, 2009 | Samsung HT-Z310T Theater System
I see'protection' then it turns off
Protection means the unit is detecting a short somewhere. Disconnect speakers and components and attempt to power on the unit again. If it will power on with nothing connected, repeat the process (turn off, connect something, then power on) until you find the bad component or speaker.
Dec 31, 2008 | Samsung HT-DS100 System
F61 code
yes i did see this code F61  but turned off and back on and the surround and center speakers still don't work
Jan 06, 2008 | Panasonic SC-HT720 System
My DVD Home Theater System Panasonic SC-HT 75 no sound at all.
http://www.usersmanualguide.com/panasonic/dvd_home_theater_sound_system/scht75
Dec 14, 2007 | Panasonic SC-HT75 System
Panasonic SC-HT820V System Logo
54 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
