Question about Sharp AR-F152 Fax
Our company has a multi-use Sharp mx-m350n system. When we fax out a 8.5 x 11 sheet, the recipients will randomly get the fax covering only 1/2 sheet (so the information is scrunched in size) while other times, the fax received if full sheet sized (8 1/2 x 11). What would cause this? Is there a specific setting that needs to be changed so that all outgoing faxes are received full page on the recipient end? Thanks -
5 Suggested Answers
  • 208 Answers
SOURCE: Recipient receives a black page
What happens when you make a copy on your machine?
Posted on Dec 11, 2007
leroyal
  • 2120 Answers
SOURCE: Outgoing faxes
Not good! It sounds like you have a bad scanner assembly. Make a copy of something and you probably will see the same result.
Posted on Sep 26, 2008
POCBM
  • 121 Answers
SOURCE: Sharp Fax - Change outgoing name/number - HELP!
Try this:
http://www.sharpusa.com/files/fax_man_FO_DC500_600.pdf
Hope it helps
Posted on Mar 14, 2009
  • 48 Answers
SOURCE: Sharp Fax Machine UX-485 recipiant receives black page
If you receive clear copies. Make a test copy. If it come out all black. Yes replace your fax . you have a bad scanner . cheaper to buy a new fax.
Posted on May 27, 2009
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
Sharp copier mx-m350n
Custom Settings > Key Operator Settings > (enter access code usually 00000) > Image Send Settings > somewhere under this heading is the Fax setting to control transaction reports
Oct 25, 2013 | Sharp Office Equipment & Supplies
Unable to print double sided on sharp mx-m350n with window 7
I had the same exact problem. Go to control panel>hardware and sound>devices and printers. Right click the printer and select printer properties. Click the configuration tab and make sure the duplex module is checked. This should solve your problem.
Jul 03, 2012 | Sharp Office Equipment & Supplies
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
How to clean data off harddrive
It should say in you admin operators manual or go to settings and then admin password, which should be "admin" and look through there and hit factory default. That should do it, if not I can check further.
Apr 30, 2010 | Sharp AR-M350N Copier
How do you put a ip address in a sharp mx-m350n thank you.
Here is a link the administrator manual (http://www.sharp-ro.ro/dyn_pdf/doc-MX-M350N-139.pdf) on page 13 it tells you how to set the IP address.
Jan 22, 2010 | Sharp MX-M350 All-In-One Printer
Sharp MX-M350N Error CE-03--We changed ISP providers and can't get Inbound routing to an email working again. I changed smtp server in "Network Setup". The "Connection Test" passes for SMTP. We can email...
CE-03 is a communication error, obviously. Your print card and your new SMTP are not talking together. Your system is probably OK at this point, but is unable to communicate well with the new network system. Work with an IT department to resolve this.
Jun 02, 2009 | Sharp AR-M450N Copier
Explane how to use fax.
It is similar working on ur phone . Switch on ur fax machine. dial the destination no. . With the cover sheet at the top arrange other sheets carrying the information under the cover sheet in order and feed it to the fax machine feeding tray . The cover sheet is one which contains the recipient identification and ur identification in it
Mar 08, 2009 | HP Officejet 4355 All-In-One InkJet...
FAX TRANSMISSION
I have had this issue as well faxing to any area code in general outside of my own. The only thing I found to work was manual faxing. This comes from the manual.
Dial manually from the handset
1. Load the document into the ADF.
2. Call the recipient on the handset.
3. When the recipient is ready(when you hear the fax sound), press Start Fax on the product control panel.
Oct 03, 2008 | HP Laserjet M1319F Laser Multifunction...
Sharp AR-F152 Fax Logo
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
