Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Display problem and not cold
The digital temp display for the freezer & fridge inside the fridge turns off. If i pull the power cord and plug it back in, the display lights up momentarily but then turns off again.  Also the Fridge and Freezer are not very cold.  Freezer is 22 and fridge 44, can't get it colder?  Thank you for your help.
  • JiggAsh May 26, 2008
    If I can, I'll do it myself. What do you think?
    Genius:
  • 3,422 Answers
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on May 25, 2008
  • Priya darshan May 26, 2008
    I recommend you to get it repaired by a tech.
    If you need anymore help let me know.
    Please don't forget to rate the solution
    Genius:
  • 3,587 Answers
Sounds like your internal control board took an early retirement. You up to doing this yourself, or do you want to search the repair listings for someone nearby?
  • Patrick Michaels
    Patrick Michaels May 26, 2008
    depends on your technical and mechanical proficiency..and patience level. what do you think of those issues? Is this item out of warranty?
Samsung fridge freezer
Sounds like it has a brain cramp. Try unplugging the power cord, wait a few minutes and plug it back in. Also look for resets near where the power cord comes into the unit.
Feb 18, 2014 | Refrigerators
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
Digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigertor isn't cold at all
Hello sewing6
Welcome,
You said,
digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigerator isn't cold at all
Try turning the fridge and the freezer off at the controls.
Then turning off the breaker for the fridge for 5 minutes .
then turn the breaker back on and restart the fridge and freezer!
This should reset the system and solve your problem.
let me know how it goes.
Thank You,
Huuum
Please remember to leave a rating! Hopefully a "solved "one.
Oct 12, 2008 | LG Refrigerators
I have a side by side refrigerator/freezer by samsung and on the digital display the fridge temp (currently set to 2 degrees) is flashing.what does this mean many thanks
If the blinking continues, you may need to “reset” the Refrigerator. Try unplugging the appliance, wait for
around 10 minutes and then plug the power cord back in.
Jul 11, 2008 | Samsung Refrigerators
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
93 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
