Question about Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman GT 3000 will not drive forward or reverse,belt seems ok
  • 110 Answers
Is it a hydro drive or gears? If hydro the trans-axle is bad & needs to be replaced. It is an easy but expensive job.
Posted on Oct 23, 2010
Craftsman yt3000 model no. 917.288517 changed v-belt drive when put in gear to go forward it go's backwards put in reverse it go's forward ?
You've obviously performed the v belt replacement bass-ackwards. Recheck the belt routing scheme in your manual.
Jul 16, 2017 | Craftsman Garden
Craftsman ltx 1000 18hp tractor will no longer go forward but runs normal in reverse
First replace the drive belt. (1/2 x 82-1/4) and the V-idler pulley if plastic, Reverse doesn't load the belt as much as forward drive. The reason I suggest replacing the V-idler too is that the plastic wears heavy and the drive belt bottoms out causing slippage.
Then if it doesn't drive forward then you most likely have a bad transmission.
Nov 24, 2014 | Craftsman Garden
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
Yt 3000 42" will not move forward or backward
Your drive belt might be off or broken (upper one) not the belt that controls the blades. There's a rod at the rear of the mower that also controls the trans-axle, if it's pulled out, the transmission is disengaged. To purge air out of the system, you pull the rod out, keep it in the out position with a pin and move the motion lever to go forward and return it to neutral several times, then do the same thing to the reverse direction. Then release the rod and return it to the very most inner position. GOOD LUCK, hope it's not a bad transaxle.
Feb 24, 2014 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Craftsman 20.5hp briggs and stratton will not go forward or reverse when I let off the clutch it starts to squeal and smokes fronm the drive belt
could be as simple as a worn out belt but look to see if there is a oil leak getting onto the belt
May 04, 2012 | Garden
Mower starts, but won't move
I would first look at the drive belt for damage or to see if it has derailed.
May 16, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No power when drive is engaged
Hi
Check your drive belt and the tensioner pulley that holds tension on the drive belt. Its possible for the tensioner pulley to be sticking and not putting enough pressure on the drive belt causing it to slip.
Grab hold of that tensioner pully and make sure it moves in and out freely against the drive belt.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 24 Hp 48" Deck Yard Tractor Logo
472 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
