Question about LG DH30 GoldStar Dehumidifier
Was wondering is the goldstar qs064cab on recall
I have a Frigidaire Dehumidifier model FDB30R1. Is there a recall for fire hazzard on this model?
Richard?
I have provided you a website that may help.
There has been a recall since 2013. Here below is the website.
My advice. Contact Gree. Be persistent and kind. Customer Support Reps, being people, can do wonders sometimes when they are treated kindly.
https://www.cpsc.gov/Recalls/2013/Gree-Recalls-12-Brands-of-Dehumidifiers/
Dec 03, 2016 | Frigidaire Dehumidifiers
Goldstar dehumidifier dh404ey7 starts and runs about 5 mins., then trips house breaker in all different outlets.
any appliance that trips the fuse or breaker should not be tried to use by homeowner this is a fire hazzard as an electric short is a dangerous situation to have in any home , replace unit ! ck with mfg for recalls first and warrentys as well then contact your power company sometimes they give rebates for appliance upgrades but they require old ones back in order to pay u money on them
Oct 02, 2014 | Goldstar Dehumidifiers
I have a DH504EL. Should the fan run constantly? It hums, so I know the motor is running, but the fan isn't moving>
if the fan is simply humming but not turning over take the back cover off and make sure the blower piece is free turning. i used to have a dehumidifier(goldstar similar model long sold though) it had a bad thermal fuse in the fan motor but compressor worked perfect. bolt is i think 10mm and i had to peel the tape off of the motor windings to get at the fuse. soldered new one in(p/o gave me new fuse and 10 bucks to get it out of his hair what a deal:) ) and retaped the windings. also the felt bearings may be loose but i just lubed the front and back bearing housings well with syn-lube(valvoline for brakes) and reassembled. baby oil works wonders so does vasoline but due to heat that trick does not last long before making a racket and leaves a **** on the assemblies underneath(mess) so try the high temp lube or any moly based brake lube
Sep 12, 2011 | Goldstar DH504EL Dehumidifier
I have a GoldStar Humiity Control DH504ELY6 , I need the PWB for
why do you think the pwb is bad? you gave no symptoms or problems.
Apr 05, 2010 | Goldstar DH504EL Dehumidifier
LG DH30 GoldStar Dehumidifier Logo
138 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
