Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
My vacuum is not turning at the bottom. I cleaned out all the hair that was wrapped around the cylinder... Not sure what do do next. Thanks! Jenny
reddevil6
  • 1673 Answers
SOURCE: Wheels stop turning
Model number would help. If this one has a V belt and a flat belt, then the flat belt is broke, or come offthe motor pully, or is stretched enough that it won't drive the wheels. Which is #12 on the pic. part #38528035, the V belt part #38528034.
Posted on Feb 13, 2008
  • 389 Answers
SOURCE: hair on top of washable filter on d14 animal
One way or another, dirty air is by-passing the cyclone. Check that all the seals are undamaged and in place, especially the big black ring at the bottom of the yellow bit inside the clear bin.  Also check that the bin base closes tight after you've emptied it.
If this doesn't help, please post a response and I'll try again.  If it does help, please remember to rate me!
Posted on Apr 21, 2009
b0sslady2001
  • 357 Answers
SOURCE: Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
http://cgi.ebay.com/DYSON-VACUUM-DC07-DC14-DC-07-14-BRUSH-ROLL-BEATER-BAR_W0QQitemZ120452265897QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b83b7a9&_trksid=p4634.c0.m14
Marci
Posted on Aug 07, 2009
beltronic205
  • 1460 Answers
SOURCE: I took the vacuum apart, and cleaned the filter,
Check its assembled correctly . Sounds like something is out....
Posted on Nov 27, 2009
Vac Belts
  • 701 Answers
SOURCE: When switching the vacuum (DC17 Animal) over to
The drive belt has probably broken. You can get a replacement belt here:
Dyson DC17 Belt
Posted on Dec 05, 2009
Vacuum squeaking loudly!!!Help!!!!
Most likely has a bunch of hair wrapped around the beater bar. Get some scissors, razor knife and some needle nose pliers. Turn the bottom up and remove the cover and start digging the hair out. You may need a new drive belt too.
Nov 07, 2015 | Vacuums
I have a Lindhaus powerhead MOD.PB12e SN123463. The powerhead turns on and the roller starts turning but after a couple of seconds it starts sounding like something is not letting the roller turn properly...
A common problem is for hair to get wrapped around and forced into the end bearings which causes the motor to work harder or drive belt to slip. Cleaning the hair out can be a short term fix but new bearings might be needed. It's also a good idea to replace the drive belt at the same time as the slipping belt is probably not going to perform well even with new bearings.
Mar 03, 2015 | Lindhaus Vacuums
Why does my Roomba 620 keep stopping when it comes to an object
Does it stop or does it stop and turn to go around the object? I would clean off the sensor. I know mine gets dusty.
I say this to everyone, you must clean out any vacuum, especially the Roomba often. My Roomba gets hair and thread wrapped around every moving part. Turn it on it's back, open the two catches on the right and left. Remove the two spinning bars. get all the hair out of every place you see it, yes even wrapped into the "axles" on each end. Also the ball white/black wheel at the front has to be pried out and the hair removed from this axle. Otherwise it can't turn as easily.
Jul 07, 2014 | iRobot Roomba 560 Robotic Vacuum
How to clean the rotary brushes on the bottom of the vacuum
Just use a razor knife to cut through the hair, string, etc. that may be wrapped around the brush. It is easier if you take the brush out of the vacuum and that will also let you examine the bearings at each end to see is they need to be cleaned as well.
Mar 09, 2014 | Oreck XL2600 Vacuum
Brushes will not rotate
I can't tell for sure from the pictures, but there are two possibilities - the drive belt to the brushes broke, or the brush can't turn due to excessive hair wrapped around the shaft. If the belt is OK but the brush does not turn, you should smell burning rubber.
If the belt is broken, you have to remove the bottom plate to expose the brush, remove the brush and the broken belt, and replace the belt, and put it back to gether. While you have the brush out, now would be a good time to clean it - remove the hair, etc from the brush and around the shaft. Good Luck!
Dec 19, 2012 | Hoover F7210-900 SteamVac V2 Upright...
My floormate is not suctioning very well. Tech support told me to take out the brushes and put them back in and this helped for a little bit then it went back to not suctioning. deb
When you took the brushes out, was there hair wrapped around them? Sometimes they just need to be cleaned off. When you take them off, there is a belt they connect to that also goes around a gear -- make sure the belt and gear don't have hair wrapped around them either.
Hope that helps!
Aug 28, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
No suction on Bissell Powerforce Bagless. Have thoroughly cleaned
Make sure you unplug before cleaning turn vaccum upside down check roller
for hair and strings wrapped around brush if this does not help clean out cylinder gently knocking dust out or use a duster to stick up inside lightly cleaning and check filter
Sep 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
Hot Smell when I run it
Check to make sure there is no hair on the ends of the axel. Hair will sometimes wrap up around the axel and make it hard to turn. Cut off with razor and place a drop of oil on the ends.
May 08, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Roomba brushes won't spin
I had this problem with my Roomba Discovery. I ran across your question while searching for an answer. My main symptoms were, Roomba hesitated a lot, and the dust bin did not fill. I had plenty of hair wrapped around the brushes and against the filter.
I just finished taking my Roomba apart. I found the motor drive shaft had a LOT of hair wrapped around it and it had climkbed into my gearbox. I took that apart and cleaned all the hair out of the gearbox. My Roomba is back to normal now, filling the dust bin.
Jun 28, 2008 | iRobot Roomba Red 4100 Bagless Robotic...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
93 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
