Question about Casablanca Fan W-52 Remote Control
WILL THE CURRENT W52 SERIES TRANSMITTER AND RECIEVER WORK IN AN OLDER CASABLANCA FAN THAT CURRENTLY USES A W52-060 TRANSMITTER.? THE PART NUMBER IS 7854030
2 Suggested Answers
vinceisaac
  • 2432 Answers
SOURCE: Have an older Casablanca fan.
hi sir have you been clean the battery terminal.then to check if the remote controller is working you need a digital camera or a cellphone with camera now turn on the digital camera in capture mode and then point toward to the camera the remote controller and press any button if their is a light appear on the screen display of the camera the remote controller is good. the problem is with in the receiver sensor of the casablanca fan. how ever if no light appear on the display the infra red sensor or the electronic circuit from your remote controller will be the problem. hope this may help feel free to ask further question thanks for consulting the fixya.
Posted on Aug 08, 2011
I need to change the receiver and transmitter of Casablanca Scandia Ceiling Fan 88u33m. How to open the fan / dome and is there a newer replacement for the receiver and transmitter.
remove fan from ceiling [ safer way to work on it ] and receiver is in wire cover and any place that sells fan usually have a remote system
Jul 14, 2017 | Dryers
I have a Casablanca slumber three delta ii that I want to get a light fixture to fit. Can I use a Hunter, or are there certain ones I need to use?
You have to use the bottom plate to attach the light kit to so whatever you get ,you have to be able to screw the two screws back on the fan. I have some older Casablanca light kits that will work without the bottom cap. fanman9952@aol.com
May 13, 2015 | Casablanca Fan Dryers
What does a choke coil do
choking coil - a coil of low resistance and high inductance used in electrical circuits to pass direct current and attenuate (block) alternating current
Nov 08, 2014 | Casablanca Fan Televison & Video
I have a 16 year old intelitouch fan from Casablanca. I was trying to change the light bulb, but after turning off the power to change the bulb, the power would not return to the fan. I have two wall...
I have a casablanca intellitouch ceiling fan and if you change a bulb while the unit is powered on you ruin the control board. The control boards are expensive but easily replaced by a diy-er. I think I have encountered this problem twice. These fans are very well made and in the past I decided it was worth repairing. However with the new fan technology out there it would be wise to shop around and weigh your options.
Jul 10, 2012 | Casablanca Fan Dryers
I have an existing Casablanca Lanai Fan Model 79669D installed in ceiling. Is it possible to install remote control after the fact?
yes they have a kit at all hardware stores, you will need to take down the fan to put it up it is easy just use two people works out alot better, good luck ps dont forget to turn the power off before starting
Aug 07, 2011 | Casablanca Fan CAS 79669D Lanai Ceiling...
My Casablanca ceiling fan model p4m55h has worked fine for about 2 years. Now the remote will not operate fan or light. I have checked light switch wiring (all ok) replaced battery in remote, and checked...
Hi, my name is Shaun. Welcome to FixYa. I have been an electrician for 6 years, and I have to say that your troubleshooting skills are impressive. Looks like you have covered all the bases. So, to answwer your question, the problem is most likely, yes, your reciever in the fan, unless the transmitter has been dropped or damaged in some way. Recievers rely on transitors to close the higher voltage circuits to turn on the lights and fan, and these tend to burn out occasionally. I believe you can buy wireless kits from Home Depot or Lowes that include both transmitter and reciever. In the meantime, you can rewire your fan and light to operate from the switch if you have pullchains or seperate switches for light/fan. If you do and you would like me to walk you through this process, reply to this answer. Hope this helps out. Have a good one!
May 09, 2011 | Dryers
How do you program a casablanca fan remote control to work for the fan?
Howdy,
Casablanca control systems are specific, for instance Inteli-Touch (4 button wall control with power fan light and reverse buttons) uses power line signals to a computer board inside the fan's motor housing and a remote control using RF will not work. However, you do not state what control you have, or what specific control you wish to attempt to use with the fan. Some will work some, will not.
Thanks and Reply so I can better help you!
Sep 14, 2010 | Casablanca Fan (3845T) Brushed Nickel...
Casablanca Vary Quiet PC Board for Series 4000
First, the resistor you are looking for is a 39K ohm +/- 5% tolerance (GOLD tolerance band). Second, FAN MAN still has a couple of new boards in stock, even though his website says he is sold out (I just spoke with him today). VERY nice guy, and VERY reasonable prices. Phone # is (866) 600-FANS (3267). I had the same problem a few years ago (burnt resistor and fried pot) and replaced the resistor and pot. Everything worked again with very little time to fix, and almost no cost. Got the resistor at Radio Shack, but had to order the pot from a Casablanca dealer - read on.......
Now for the pot......
Part #1954150 *IS* a 5K ohm linear taper. I'm looking at the meter and a new pot as I write this. You had me wondering if I misread the meter or something, so I went back and double/triple checked. This pot is installed in my recently rebuilt Vari-Quiet Victorian, and it works fine.
However, I want to tell everyone that I had purchased a replacement pot many years ago from a Casablanca dealer because, as I said above, my old one had fried, along with the resistor (just like your situation). The pot the dealer sent me was a Casablanca part 0001040 (I still have the receipt), and it fit perfectly, so I didn't pay much attention to it. This pot worked for over a decade. But the replacement pot was NOT stamped with the 1954150 part number, and I have long ago thrown out the original - so I don't know at this point what was originally in the fan. BUT, the replacement pot that I put in so many years ago *IS STAMPED* "25K Ohm", and I measured what is left of it and it definitely is a 25K ohm linear taper pot. It worked for over a decade (since 1998).
Now, I have once again rebuilt my fan this summer because the pot again failed (I can't complain, I got almost 11 years out of it). New bearings, new pot, new flywheel, new PCB assembly, new heat sink/transistor, new brass hardware and a a coat of paint/laquer (brass). The new pot was purchased from Plaza Lighting (978) 774-7801, Don Guerette - another VERY nice guy with EXCELLENT prices. However, I got his last pot - sorry. The pot Don sent me is the 1954150/5K Ohm linear taper - the same one that came out of your Vari-Quiet. It also works very well - better than my old 25K Ohm pot because it slows the fan to a full stop at almost a full deflection of the knob (my old 25K ohm slowed the fan to a full stop at partial deflection).
Hence, my conclusion is that the part that belongs in MY fan is the 1954150 pot, and the 25K Ohm pot was the wrong one, even though it worked for many years (no reason it wouldn't, scaling was off, that's all). If you've never done anything with your fan since new (like replace the pot), then the correct pot is the 1954150 since that is what you are taking out of it, and that is definitely a 5K ohm linear taper. You can pick these up almost anywhere. The 25K ohm wa a wire wound. I don't know about the 5K ohm as I'm not about to take mine apart - smiles.
P.S. I was able to acquire a W52 remote control module and install it on my rebuilt Vari-Quiet. It works GREAT (Casablanca sasys you must convert it to a 3-speed before you can use the W52 - LOL)!!!!!
Sep 11, 2009 | Dryers
We are installing a lighting fixture on our Casablanca 4944D Concentra. We can get current across the various wires, but can not get the light to turn on. The colors of the wires are blue, black, red,...
On ceiling fans, the blue wire is designated for the accessory light kit. If you are using the Casablanca kit, it should be wired with a matching plug that just, well, plugs into the fan.
If you are adding another brand of light kit, you only need to connect the blue wire (hot/common) to the black wire of the light being attached, and the white (neutral) to the white wire of the light being attached.
Your fan will not have a pull chain/switch for the light attachment, as that is normally supplied pre-wired and installed in the light accessory.
If in doubt about about the wiring, contact Casablanca for a manual showing what light kits are acceptable for adding onto your particular fan model.
Also, please turn off the power before connecting the light kit to the fan.
Hope that helps and best regards!
Jul 31, 2009 | Casablanca Fan 4944D Concentra Antique...
Casablanca Fan W-52 Remote Control Logo
88 people viewed this question
Top Casablanca Fan Televison & Video Experts
Steve
Are you a Casablanca Fan Televison and Video Expert? Answer questions, earn points and help others
