Question about Toshiba A15-S1292 Notebook
Computer boots and thenm shuts downs even in bios mode
My computer was do for a tune up I put the tools and application disk
in and it woud not load from drive,just kept shuting down after startup
I went into bios after that,and I cant get passt the first part of the menu!
I see that the auto power on is disabled! is that the problem?
    Problem Solver:
  • 4 Answers
Have you tried checking if u got a floppy or cd inside?
If no, you should check the boot order, in setup.
But like 3 month's ago, a friend bought a laptop, and happened the same.
The problem was the bios.
So i went to bios setup and reset it to default.. Should work.
When a system is overclocked or some of the timings/options are set wrong this will happen. It may not apply to your situation but its worth a shot since thats most likely the case. You will find the default option in BIOS "EXIT" menu
Best Regards
Posted on May 25, 2008
I have a hp altec 255 laptop .when I put in reinstall disk .windows 7 .computer will not set it up to take program .enyway to get a new hp recovery and applications/drivers reboot disk
please check bios boot type I sujspect it may be booting for UEFI rather than for legacy boot. Windows 8 will boot on UEFI boot type but windows 7 will need legacy bios type of boot up settings in bios
Dec 21, 2014 | HP Computers & Internet
Boot menu
Your computer's BIOS, or basic input/output system, regulates several important system functions before your operating system loads.
The BIOS can even tell your operating system which device it should load from, whether the computer's hard drive or a USB stick.
You can control this and other options from the BIOS boot menu.
If you own an Acer Aspire One netbook and want to access the boot menu, you can do so by entering the computer's BIOS.
Turn off your Acer Aspire One netbook.
Turn it back on.
Press "F2" when you see the Acer logo appear as the computer boots up.
This will open the computer's BIOS menu.
Press the arrow keys to highlight the Boot option.
Press the down arrow key to highlight specific boot settings to change.
Windows operating systems support a variety of boot options on the Windows Advanced Options Menu that allow you boot your computer based on your need.
They support boot options such as Safe Mode, which is generally best for troubleshooting and virus removals; or the Safe Mode with Networking, which allows to use an Internet connection while troubleshooting system problems.
Within seconds, you can access the boot menu and select the option that works well for the task you want to accomplish.
Shut down all currently running programs and restart your computer.
Press "F8" repeatedly before the Windows icon shows up on your screen.
This will bring you to the "Windows Advance Options Menu."
Scroll down and select the boot option you want.
Press "Enter."You can select from "Safe Mode" "Safe Mode with Networking" or your regular booting option.
Choose the boot option based on your need.
For troubleshooting, it is advisable to select "Safe Mode" because only a certain amount of drivers and resources run allowing you to resolve issues.
Jun 28, 2013 | Acer Aspire One D250 (99802378332) Netbook
Flash bios lenovo 3099-1uu
It sounds like your hard drive may have failed. I would suggest the following to confirm.
  • At the splash screen, press F1 for BIOS Setup Utility.
  • Ensure that you see HDD and that it has a device id next to it
If you can see it, then you may have an operating system boot issue. If you cant see it then it might be an idea to remove the HDD and re-seat it. There may also be a setting in the bios for booting from an older operating systems such as XP. I think it might be a setting similar to "Boot mode set to UEFI" etc.
Another good tool to check hardware and get a device booting that may be missing the boot files etc, is to use an application called HIRENS. It can be put onto a USB stick. You can also do a hard drive test with it
The link is
To be honest I don't believe a bios update will do anything for you. But you could try loading the default settings etc.
I hope this helps
Nov 24, 2017 | Lenovo Computers & Internet
I have massive boot issues...Can't enter BIOS>laptop freezes. Can't load windows in any form safe mode or otherwise. Can't install new copy of windows either freezes or gives a file not...
If you can't even enter the bios, it means you have a hardware failure somewhere, as the bios is independent of the operating system (Windows) and only needs a functional power supply, motherboard, CPU, RAM and of course keyboard to navigate. A hard drive isn't even needed to enter the bios. In fact, it might be a good idea to remove the hard drive and try again to enter the bios, in case the hard drive interface is causing an issue. If you do manage to get into the bios, try to navigate to where you can set the bios back to factory default. If you still can't enter the bios after disconnecting the hard drive, then it's a matter of trial and error, swapping out RAM, the power supply, CPU and removing any other peripherals that may be removable (like a wifi card or DVD drive). If you can't reliably get into and then smoothly navigate the bios, I'm afraid it is unlikely that you'll be able to install and boot Windows.
Nov 13, 2017 | Fujitsu Siemens Amilo M1425
I have dell inspiron laptop, suddenly a problem occured I quot that :windows faild to start a recent software or hardware change might be the cause to fix the problem : 1-insert your windows...
Shut your computer all the way down. As soon as you turn it on, start hitting F8 about 3-4 times, that will take you to an advanced options menu. Select "Last known good configuration" and that should work
Mar 08, 2011 | Computers & Internet
My computer will not boot up keeps closing down
check how often it shuts down and if it shuts down when you start a particular application then start your computer and go to BIOS and leave it on there ( for example if your comp shuts down every 3 mins in normal mode then leave the comp on for 15 mins in bios to determine if it is a hardware or software issue then check in sfae mode the event log or error reporting if any hardware is causing the issue, update the drivers or try with new user or reinstall OS as last option.
Aug 10, 2010 | Acer Computers & Internet
Insert smart card into reader problem
I think its looking for a boot command from the card reader. Which means pressing the DEL or F10 or F2 key repeatedly while booting to get into your bios to change your boot order.
If it wont let you, try booting while pressing the F8 key, with luck it may bring up windows boot options, choose the safe mode. When up, Click on Start - all programmes - accessories - system tools - system restore - choose a date prior to problems. (This is for XP, Vista and Win7 slightly different)
Boot from your windows disk, and choose the repair option.
Or download, UBCD4Win , the ultimate boot cd for windows, This will load a windows shell system with loads of diagnotic and repair tools.
You could download and run Ubuntu without installing, that will give you access to any data files.
If none of this works, the only recourse is to re-install windows. But in
doing this, you will be re-formatting the hard drive which will remove all data on the drive.
If you don't have a copy of windows, you do have Ubuntu. I use it nearly all the time now, even though I have a dual boot system.
Jul 21, 2010 | HP Compaq nc6230 Notebook
Computer starts to load and then shuts down
Please ensure that your hardware supports Windows 7.
Mar 28, 2010 | Gateway GT5662 Desktop PC
It is constantly on the loading circle on vista and take ages to load any programs and wont let me shut down
When the laptop boot up press F8 and F5 several times to come onto a boot menu, choose to boot in Safe Mode.
If it still slow then it's a hardware problem (HDD, RAM, Micropro...).
Usually it's the hard drive, to be know you can try to boot from a usb flash disk with linux for example or another HDD of course, you will have to enter the bios to change the boot sequence.
If not Windows has some trouble (virus, file missing...etc.), put vista cd and use his tool to fix it ( backup everything before because you might LOOSE all your data). If it's a virus...Mmmh...long process to clean it ...but if you have time try as many free antispyware,antivirus, trojan remover, worm remover... as you can. One after another preferably.
Good luck and don't forget to rate.
Jan 23, 2010 | Acer Aspire 5610-4648 Notebook
When It goes to loading screen it restarts
It is becasue of your computer is not properly shut down and so your harddisk has some bed indexing of memory location.
For that you need winxp disk or recovery disk.
Then boot your computer with that disk .
You have to set first boot device as your cd or dvd rom.;
For that when you power up press F1 or F2 or "del" key to enter in bios .
Then go to boot option then sewt first boot device as your cd or dvd rom.
then save settings then put winxp or recovery disk in rom.
Then follow the procedure .
Then enter in recovery console then type in prompt "chkdsk /r"
then it fix error on harddisk.
Sometimes this command fix eror and then after restart windows load normally but sometimes need to repair windows.
So after check this if still face issue just chose "r" when it finds your previous version of windows then it recovers your windows.
Let me know if you need more assistanse.
Sep 04, 2009 | Computers & Internet
Toshiba A15-S1292 Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
