Question about GE Dishwashers
GE MOD. PDW7880J15SS DISHWASHER - WORKS IN PRE WASH ONLY AND NO LIGHTS ARE SHOWING - WHAT'S THE REPAIR
5 Suggested Answers
SOURCE: GE Max dishwasher no lights on panel
I reset the breaker and still doesn't work. Any suggestions?
Posted on Jun 22, 2008
rickzilla
  • 706 Answers
SOURCE: plumbed in new dishwasher wash
Hello lozjojo,
Based on your problem description, you either have no water pressure at the inlet valve or the inlet valve isn't operating and allowing water in. Prior to installation, did you make sure you removed ALL the packing material from everything? Is there any way tha you can check your supply lines for water? Also, some of the new flex water supply lines have built in anti leak 'shuttle valvles' inside them to prevent flooding if the line bursts.. Unfortunately, I don't know how you tied in the supply lines to the dishwasher itself.. If you used the anti-flood type supply lines.. that is another consideration to investogate.. If nothing I suggested resolves your problem.. please elaborate on the method you used to supply water to the system.. Good luck .. and hope I helped you...
Regards
Posted on Oct 11, 2008
SOURCE: i have a hoover dishwasher and it starts pre wash
THE PROBLEM IS THE LITRE-COUNTER SWITCH AND IF YOU CUT THE PLUG OFF, SOLDER THE WIRES AND SEAL, IT WILL WORK AGAIN NO PROBLEM, ITS COTACTS THAT GET MOISTURE ON THEM. EVERYBODY THINKS ITS PCB OR PRESSURE SW BUT ITS DEFO NOT. I KNOW BECAUSE I WAS A HOOVER ENGINEER.
Posted on Jun 11, 2010
  • 3247 Answers
SOURCE: My dishwasher get stuck after
It is likely the drain pump or hose is blocked.
It might be helpful if you can provide the full model number of the candy dishwasher.
Posted on Dec 12, 2010
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
For a ge dishwasher mod#ghda485nools:on startup mode lights blink and pump turns for 10 seconds then shuts off
00023396.gif small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
transparent1.gif Find a part for your Dishwasher godark_3.gif How Dishwashers work godark_3.gif What is wrong with your Dishwasher? godark_3.gif Email the RepairGuru for help with your specific problem godark_3.gif Maintenance tips for your Dishwasher godark_3.gif Answers to common questions about Dishwashers (FAQ) godark_3.gif Locate your Dishwasher model number godark_3.gif Accessories for Dishwashers godark_3.gif Appliance Recall Information godark_3.gif RepairClinic.com is the web's best resource to buy parts for your Dishwasher and get free Dishwasher repair advice for all major brands of Dishwashers including Admiral, Amana, Asko, Bosch, Caloric, Crosley, Electrolux, Estate, Frigidaire, GE, Gibson, Glenwood, Hotpoint, Insinkerator, JC Penney, Jenn Air, Kelvinator, Kenmore, Kitchen Aid, Magic Chef, Maytag, Modern Maid, RCA, Roper, Tappan, Thermador, Westinghouse, Whirlpool, White-Westinghouse, and more.
Jul 04, 2008 | GE Dishwashers
Timer light on front panel of dishwasher has stopped working--how is it replaced?
Most of the led lights are fused to the circuit board. Sounds like the circuit board is going or gone bad. I'm not sure because you did not give the model of the dishwasher.
Most of the control lights are led and do not go bad. But the circuit board that controls the lights can go bad. You may be able to fix the control circuit board but replacing it would be easier.
Oct 14, 2014 | Maytag Dishwashers
I have a GE quiet/power2 MOD D5560LOOSS It doesn't release the soap from the dish. It wasn't cleaning dishes well and then it completly stopped. I have tried different settings. It sounds as if...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 13, 2011 | GE Dishwashers
My dishwasher get stuck after the pre rinse with both lights ,the pre rinse and wash lights flashing,failing to go to the wash programe.
Dec 12, 2010 | Candy Dishwashers
Hi my hoover 6612 dishwasher does its pre-wash but then when the light for wash comes on it does nothing. I wondered if it might be a capacitor which needed replacing but I can't find one - any ideas??
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
Check start capacitor on the left side of the wash motor
Mar 13, 2009 | Dishwashers
3 year old GE dishwasher dead!
Buy a different brand of washing machine. I suggest a front loading one because they use so little water and they are cost effective and actually pay for themselves.
Jun 09, 2017 | GE Dishwashers
Dishwasher pump motor stops
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Manydishwashers heat the wash and/or rinse water to a higher temperature,as the cycle calls for it. In these cycles, the dishwasher pauses afterit has filled with water, waiting for the water to reach the pre-settemperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • Onothers, the cycle can't continue until the water reaches the highertemperature. If you have this type of dishwasher and the water isn'tbeing heated (say, because of a problem with the heating element orthermostat), after the unit stops at the heating cycle, it nevercontinues. When you repair the heating-system problem, the "cycleproblem" is fixed too.
Timer Timersdon't often fail. But if every other part of the dishwasher seems to beworking properly and the timer knob seems to be stuck in oneplace--doing one function continuously--the timer may be at fault.Dishwasher timers can't be repaired. If yours is defective, replace it.
Dec 10, 2008 | GE Dishwashers
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
Feb 04, 2008 | Dishwashers
Dishwashers Logo
82 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
