Question about Craftsman Garden
Model 358.350880 broken starter rope on chain saw. Upon taking apart, it was not apparent how the cord should be installed. Additionally, there is some small gouging to the flywheel where the small "keys" engage the pull starter.
  • 17 Answers
SOURCE: Pull cord on chain saw will not retract.
Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
Posted on Jan 03, 2009
  • 6 Answers
SOURCE: Chain saw starter rope won't recoil
recoil spring is broke. homedepot has a new one
Posted on May 23, 2009
steve_lima
  • 181 Answers
SOURCE: HUSQVARNA model 435 Difficult starting
the problem is in the ignition coil.it needs to be replaced.it is under warranty.its warranty is life time.call husqvarna and they will either send you a new one or send you to a husqvarna dealer to fix the problem.that is at no cost to you..............let me know if this helped.................
Posted on Jun 06, 2009
  • 61 Answers
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Posted on Jul 04, 2009
bobbyburns
SOURCE: Reattaching the recoil spring to the rope pulley
i have the same probelm
Posted on Jul 08, 2009
When pulling starter rope , it has a strong pull back on your hands. the point gap is correct, and the fly wheel key is not sheared or broken.
check the clearence on the stator between the pull cord componet and the spark plug stator, if might be touching
Oct 02, 2013 | Homelite C-72 Chain Saw Parts Manual
Cord rewind assembly
If you place the chain saw on a work bench with the bar and chain pointing at you. We will call the side with the chain and bar the left and the side where you gas and oil the saw the right side. Now on the right side just behind the oil filler cap is the starter rope and assembly . There are four screws that holds this assembly to the saw. Remove these 4 screws while carefully watching and lifting this assembly from the saw. turn the assembly over and if you can see and grab the old starter rope . Grasp it and pull out on the rope a few times so you can see how it works, play with it a bit, so that when you replace the old rope with a new you will be familiar with the action.You can find starter rope at local chain saw or hardware stores, estimate the length you will need. Re-thread the new rope in opposite direction that you saw the old rope function being careful to duplicate the knot at the end of the rope which will be inside the assembly, threaded in as you saw the old one come out. So look carefully. Play with it a bit. Familiarize yourself with how the two holes line up and thread through the spool and the knot is tied. Now make sure the end of the rope coming out of the assembly has the recoil action. Tie on the handle being sure to take only enough re-coil that there is no slack in the rope and handle end. Replace the assembly and check the action. Have fun! Alvin
Sep 30, 2013 | Husqvarna Garden
Installing a spring in an MS240 Stihl chain saw
I have not worked on you type saw. I have put new starter springs in other saws. One end of the spring fits into the housing and the other in the pulley. Once you have that done there should be a notch in the pulley that you put the rope into that will allow the spring to be wound up without taking up the rope. It is a trial error problem now. If the spring is wound too tight you will not get full rope travel. If it is too loose tilt will not pull the rope in fully.
Jun 01, 2013 | nwp Starter Recoil Spring Fits Stihl 024...
The pull cord will not retract back into the saw. When I tried to start the saw, I pulled the cord and now it did not retract back. It is all the way out and will not recoil.
When I have had this happen it means that you need to manually rewind the cord and put some additional tension on the take up pulley. To do this you'll have to open the saw up and untie the handle. Turn the pulley like one turn, put the rope back through the hole and tie the handle back on. All this is done while maintaining tension on the rope.
Feb 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Rope broke when i try to start it
Take the chain saw apart. You will see a small canister where the rope is located. It is spring loaded remove the rope install a new one and rewind the chain. Hope this helps.
Aug 20, 2009 | Garden
Poulan wild thing chain saw rope came off
by the time it would take to tellyou ,you would be better to take it to any small engine work shop. it is not difficult but it is to explain
Jul 20, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Clutch Drum Removal
Special tools may be require and can usually be purchased form the maker of your saw.
Often the spark plug is removed, the piston positioned to just before TDC, and a length of starter cord or rope fed into the cylinder. This allows the the clutch to be be removed without damaging the piston or cylinder.
1. Don't put all of starter cord or rope into cylinder.
2. Ensure the piston is above the exhaust port.
3. The threads are often left handed.
HTH
Lou
Mar 01, 2009 | Makita 33cc 14-Inch Bar 1.9 HP Gas Powered...
Rewind don't work
as you put the side with the recoil starter back on the saw, ensure the rewind pack isn't binding. before tightening the screws, pull the rope out a few inches and let it rewind. if it won't, something is binding. keep moving the side panel till it will rewind. I have done this before myself. get it all put back together and it won't work.....
Jan 29, 2009 | Poulan Pro Chain Saw 46cc 20"
Jan 02, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
