Question about Samsung HCN653W 65" Rear Projection Television
I have a samsung HCN653WX/XAA tv. i had red wavy lines across the screen and was told that the audio video input board was bad. so purchased a brand new board, and installed it. after turning the tv on for the first time, i discovered that the lines were still there, and now the colors arent aligning up, and the perfect focus doesnt work, it gets to 22% and then stops. the screen also has a bow in it on the top and bottom. Would the convergence board cause this? or could it be something with the audio video input board
  • 18 more comments
  • littlekxride Oct 05, 2010
    just to give you a little more of an update, i just replaced the convergence board today and the problem was the same. With the old audio video input board, there were just the red wavey lines, when i tried to do the perfect focus, it only went up to 4% with the new convergence board and the old audio/video input board. it wouldnt go past 4% and then just went back to the tv screen. i noticed as soon as it went back to the tv screen the image was better, but then after a few seconds, it went back to the red wavy lines. When i put the new audio/video input board in with the new convergence board, there are 3 images of everything, red green and blur i believe. and when i hit the auto focus, the % bar at the bottom crooked, and it wont go past 0%. i will get pictures to you in about an hour, im at work right now.
    ok i will just send them to the email
    ok. i will be home at 5 so as soon as i get home i will send it
    ok. do you wont a picture of it with both the new audio/video board and the old one?
    yes there are red lines on both. they look a little different on the dvd side. but they are there
    yes. the lnes are on all imput screens
    i dont have the service book. so what can i do to diagnose it more?
    i apologize. as far as the convergence goes. the colors are all lined up. no problems with that. i will check the connections now. wich sodders should i pay attention to
    ok i checked the red wires and they are all tight. i checked the soders on the bottoms of the board next to the audio/video input board and they all looked good. thats the board you were talking about right. the one with the black box with the one thick red wire coming out?
    i dont know anyone with this tv. i will contact a repair shop though. how much does this board usually run? and is there anything else it could be
    ok. just to clearify. the new board i got was an entirely different problem. i couldnt tell if the lines were still there because the image was that bad. is it possible i got a bad board? and it still may be the video/audio input board?
    ok. so my next step is to find a tv repair shop with the deflection board?
    oh ok. well thankyou for all your help. will i be able to post something on this in a couple days to let you know how i made out?
    ok. thanks again
  • littlekxride Oct 06, 2010
    Hey. all the tv repair shops i am calling are saying they cant test a single board, that they need the whole tv to diagnosis the problem. is this true?
  • littlekxride Oct 10, 2010
    ok so i went to plug the power supply back into the deflection board and i heard a little pop type of noise and now the tv wont turn on. checked the fuse and its good. should i just go ahead and replace this board?
    i have a samsung HCN653WX/XAA tv. i had red wavy lines across the screen and was told that the audio video input board was bad. so purchased a board, and installed it. after turning the tv on for the first time, i discovered that the lines were still there, and now the colors arent aligning up, and the perfect focus doesnt work, it gets to 22% and then stops. the screen also has a bow in it on the top and bottom. Would the convergence board cause this? or could it be something with the audio video input board.i now replaced the convergence board as well, and still same problem.
    tried the convergence board. still same problem
    you did try to help. and i was very thankful. but after hundreds of dollars i still have the same problem and now your saying to take it to a tv repair shop. just trying to get a second opinion. not trying to spend thousands. id be better of buying a new one
    disregard the last comment. it was for the previous tech
    President:
  • 2,777 Answers
It could be either or both things you suspect, but I'd start with the convergence board for sure. It is very possible both are having issues though.
Thanks
Tim
Posted on Oct 10, 2010
  • Tim Grayson
    Tim Grayson Oct 10, 2010
    Yes you will definitely be better off just buying a new one.
    If possible please come back to the question here and click the Accept
    This Solution button, otherwise I don't get credit for the help
    provided.
    Thank you so much,
    Tim
  • 10,594 Answers
You can confirm new convergence issue cause by installing old audio-video board back and also check all connectors are plugged properly in respective jacks in circuit board.
Can you post wavy lines screen image here to diagnose its possible cause?
That will give me better idea to diagnose problem.
Thanks.
Posted on Oct 05, 2010
  • 17 more comments
  • Shahid Electronics
    Shahid Electronics Oct 05, 2010
    Thanks for update, I will wait to see pictures, especially the wavy lines in screen.
    If you face any problem to post images in this question thread, you may forward these images at welcomejee@yahoo.com without downsizing them.
    OK, I'm waiting that email
    No problem, take your time and send pictures to see tv problem.
    that will be too good to have few pictures with new and old board, I'm interested to view wavy lines across tv screen images as it is primary problem.
    OK, two pictures received, do these lines appear in all inputs? like watching dvd or cable channels etc?
    Does convergence seems ok with old board?
    These lines are some sort of distortion from deflection board side. Check red thick wires are plugged tightly in HV block that feeds high voltage to all three picture tubes.
    There could be dry solder connections in video board and deflection board that is causing these lines.
    Do you have service manual copy of this model?
    I do have similar model service manual HC-M653WX but not HC-N653WX
    If you have service manual, pass it in email.
    Thanks.
    I guess you didn't took notice of my previous post:
    "Does convergence seems ok with old board?
    tubes.
    There could be dry solder connections in video board and deflection board that is causing these lines."
    Deflection board that has flyback transformer mounted on it, its middle board, turn that board upside down and give close look to solder joints, look for dull/ blackish solder joints to resolder them, normal solder connection looks shiny.
    Your old video board is fine too as new board does not solve red wavy lines/ noise problem so no need to put new video board in tv.
    Yes, that is deflection board.
    Can you swap deflection board in similar model tv nearby, or maybe a friend have same model?
    Local tv repair shop can help you out to swap boards just to test what board is causing red wavy noisy lines.
    We are still in diagnostic process as what board is creating noisy red lines, video board is not of that as you replaced it but lines are still there.
    Once you got confirmed that particular board is defective then search it with part number written on board to find out best price.
    New video board has no convergence data, consider it as empty, and you have to perform convergence adjustment by going in service mode/ menu and it is job of professional to do that because any wrong input will turn off tv.
    Professional knows how to do convergence adjustment in new video board, then you will get converge picture to observe wavy/ nosy red lines in picture.
    Let me explain it, find a tv repair shop that can test your deflection and any other boards in tv if they have similar model tv in for some repair purpose to find out what board is causing red wavy lines to get it replaced.
    That will be good, I'll wait your feedback, thanks.
    Yes, you can post further comments any time in this question thread even if it get closed.
    OK, no problem.
    I have to answer each of your post/ comment to remain in contact with you in this question thread due to Fixya.com system design so post your next update in similar time/ hours so I can answer it quickly.
    Do not reply this post or I have to answer it again :)
    Thanks.
    Shahid Electronics Oct 06, 2010
    Any friend that has repair shop will help you
    Shahid Electronics Oct 10, 2010
    OK, I tried to help you.
    Oh well, ok
Intermittent black lines samsung hlp5067w
When the lines are showing, check to see if you can see them with the on screen menu being displayed, if you can then it is the DMD board, if you cannot then it is just the digital board.
Nov 18, 2013 | Televison & Video
Have Samsung HLN567W and recently started having
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 12, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Zenith R45W46F has sound but no picture
*Screen Looks 3-D
*Colors wont align
Jan 27, 2010 | Zenith R45W46 45" Rear Projection...
Samsung LNS4041DX/XAA White horizontal lines
Hi my name is Roety,
I can help you with your issue ,
If the lines are present on every input you most likely have a bad screen. We usually replace the mainboard first because its cheaper .
Check part prices at encompass.com login as a guest
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung DLP 50
check the input board for AVI make sure it is not dusty and that all the connections on the board are good you may have a bad solder point or that board is bad ,also possible video ctrl board
May 31, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
May 29, 2009 | Samsung HP-R4272 42 in. Plasma HDTV
Wavy lines appear across the screen
*Screen Looks 3-D
*Colors wont align
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Green Background with red wavy lines
*Screen Looks 3-D
*Colors wont align
Jan 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Samsung HCN653WX has wavy lines and red and blue ghosting
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
269 people viewed this question
Henry  Thomas
Henry Thomas
