We totally lost our dsl connection a couple of weeks ago and spent hours online with att&t getting it back but we had to disccnnect lynksys router now we want to set it up again and don't have the instrucitons. How do i connect it. right now we have a connection for one computer with the moden plugged in. Brigid
    Guru:
  • 79 Answers
Physical Setup of a LinkSys Router Each model of LinkSys router will differ slightly, but the general design is similar across all models. Therefore, the setup is similar across all models.
  1. Plug the Ethernet cable from your broadband Internet provider into the port labeled "Internet"
  2. Plug another Ethernet cable into one of the available ports
  3. Plug the other end of that same cable into an Ethernet port on your PC
Basic configuration tasks.:-
Simply open your Web Browser
Go to the URL http://192.168.1.1 This will take you to a popup box which asks you to enter a username and password.
The username is either blank or "admin" and the default password is "admin".
Once you are past the login screen, you are able to access (and change) a plethora of configuration options for your router.
Don't be worried by the enormous number and variety of options, your LinkSys router ships with default settings that enable it to work right out of the box in most environments.
If this is aWireless Router then change the SSID to identify the router as your own and configuring WEP to encrypt your wireless traffic.
Posted on May 25, 2008
    Scholar:
  • 187 Answers
First thing to do is plug in your router. Next, remove the cable from your modem, and plug it into the respective port on your router (will say "DSL" either above or below it). Next, connect an ethernet cable from the computer, to the router. Finally, log into your router via the web interface (usually 192.168.1.1)
Unable to connect to internet. Only two lights show -- power & dsl. When I called for help I was told I needed a new ethernet cable. Bought that & installed. Same problem -- only two light lit...
In all there should be lan led, dsl led, power led and internet led,
So if dsl and power led is glowing and others not?? than check the lan cable and even check the lan card of ur pc is it enabled or drivers are properly installed and same way try to check the modem configuration??
Sep 08, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
External Nortel Modem won't connect
DSL uses one wire pair since it runs off a POTS line (plain old telephone service).
The Nortel modems are very old - they were some of the first DSL systems that came out almost 15 years ago. They were designed to work with their own proprietary Nortel back-end (DSLAM) equipment. Since they use proprietary and now way outdated transmission protocols, they will not work with modern DSL connections since they do not support the standard DSL protocols. Unless there was somekind of firmware upgrade I wasn't aware of, its pretty much junk.
Nortel went bankrupt a couple of years ago. I used to work for them and some of the guys who designed their DSL modems worked a few cubicles away from me. I had a couple of them in the early days (we got free DSL as beta testers back in the mid-90's) - the modems are useless now, but I found the power supply worked well with my cordless drill charger.
Sep. 2010, Ottawa
Sep 10, 2009 | Computers & Internet
No dsl signal when the phone company checks it.
it does. i had a break in my outside line that only acted up in bad weather. mine reset by itself two thousand times in two days. they replaced the damaged line and it was fine.
Jun 18, 2009 | 2wire 2700HG-B Router (2700HGB)
Where does the phone line go in the lynksys box.
Phone Line?
You need a cable or dsl modem to connect to the internet. From the modem you run an ethernet cable to the "broadband" or "Internet" port of your router.
Also make sure your lynksys is a router, not a switch
Hope this helps
Cor
Dec 31, 2008 | Linksys EtherFast 10/100 16-Port Workgroup...
Help please
you can go to any wi-fi locations near your area and access the internet on your laptop. I think AT&T offers wi-fi access to its members on any of its designated hotspot /wifi locations (nearly 15,000 company-owned & roaming) e.g. McDonald's, Barnes & Noble bookstores, leading airports, coffee shops, etc. you can visit att.com and login to your account to find more details.
or call them at: 1-888-888-7520
you don't need to install any software/ dsl installation on your laptop when you are using a public wi-fi connection, just ensure that your computer firewall is on and take precautions when sending out any personal info online.
Apr 30, 2008 | AT&T High Speed DSL Modem
Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
Mar 05, 2008 | Linksys Wireless-G WRT54G Router
Lost internet connection
Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
Jan 06, 2008 | Trendware TEW-452BRP Wireless Router...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
