Question about Ricoh Aficio 2035 Copier
Why does my Ricoh Aficio 2035e copier produce copies with dark lines across copies?
  • 1,110 Answers
Make a copy from the glass by laying your original on the glass under the feeder and see if the lines go away. If they do then you need to clean the small strip of glass that is just to the left of the large glass. If you still get the lines then most likely the cause is a bad drum cleaning blade or possibly both the drum blade and the drum itself. If this is the case then you should be able to open the right side door and look closely at the green colored cylinder, which is the drum, and see if you see any wear lines or black lines on the drum surface. If you do then there is your cause. The drum should always be clean and shiny with no toner, lines or wear "grooves" in the surface.
The lines you are experianceing should be caused by one of these 2 problems.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Sep 30, 2010
I have an sc 326 error code in my ricoh aficio 2045 copier
If you wish to get some details; check the site linked here. Pull up older posts....
Jun 19, 2016 | Ricoh Aficio 2045e 2035e Copier...
Richo aficio 2045 out of focuse problum
could be developer powder is bad i would start there
Aug 13, 2014 | Ricoh Aficio 2045e 2035e Copier...
What is causing dark background in my copies
1. drum life is due
2. developer due
3. cleaning blade bad
4.primery charger roller faulty.
5.transfer belt claening blade worned out
Jun 26, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
What causes black streak lines on the entire copy
open the right door and look at the drum, lines on it? If not, its the hot section/fuser. -Carl
Streaks in the first copy through adf
clean the narrow glass on left of where you place the copy on glass, remove if needed to clean both sides
Mar 16, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
I reset my ricoh aficio 2035e photocopier then error sc 322 apear
error code 322 on a Ricoh/Gestener/Nashua/Aficio is usualy related to the laser unit/Polygon mirror motor, can you hear the motor starting up when you swith on the printer?it shoul sound something like an jet engine starting up, if you do not hear it then ask your local technician to replace the polygon mirror motor.
Sep 16, 2013 | Ricoh Aficio 2035E Digital Copier. 35cpm...
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
Ricoh Aficio 2035 Copier Logo
435 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
