Question about Taylor 632-33 Ice Cream Maker
I am troubleshooting a 430-12 counter top unit ... I need wiring diagrams and the sequence of operation for this unit... can you help?? Jay
Go to taylor download manual. diagrams in back will be 430-12 not 430-27
Posted on Nov 29, 2011
    Guru:
  • 1,524 Answers
Http://www.taylor-company.com/service/resources/op_man/0430op0.pdf
Posted on Oct 22, 2010
Does anybody have a wiring diagram or service manual
http://www.emga.com/files/406001_en_ol_ev_2012.pdf has the exploded diagram, not that I find it helpful. That site also has the full instruction manual
May 01, 2014 | Musso Zara 5050
I CANNOT REMOVE THE DASHER TO DISASSEMBLE FOR CLEANING. THE MANUAL FOR THIS SUNBEAM ICE SHAVER SAYS TO TURN THE DASHER COUNTER CLOCKWISE UNTIL IT UNSCREWS. FROM THE UPPER HOUSING. NO WAY IT JUST KEEPS...
Laura at ifixit posted a response 4 days ago that helped me solve this problem. ifixit(dot)com/Wiki/Sunbeam_Snow_Cone_Maker_Troubleshooting
I was unable to remove that dasher following the directions. When I turned the dasher counter clockwise it just spun and spun the motor. To fix this I removed the four screws at the bottom of the machine (hidden under gray rubber foot pieces) Removed the white base and held the clear circle motor wheel steady while rotating the dasher counter clockwise -it released in just a few spins. After reassembling the product the dasher removes per manufactures directions.
Hope others can get there machine fixed. I called Rival with this fix as well in hopes others could clean their machine. Thanks again to Laura at ifixit.com!
Aug 10, 2013 | Sunbeam Slushies Snow Cone Maker Snowcone...
Taylor 3105 windscope wiring diagram
hi john, call me about the wiring for the control box, I can help. 401-497-5817, jon terik
Apr 05, 2013 | Taylor Ice Cream Makers
Wiring diag. for mod. 407-E Ice Cream Maker
Need the serial number, voltage (ie; 115v or 208v), 60 or 50 hz.
The only exact diagram for an 407-e is 50hz.
An M will be close in most cases as long as we have the serial number or Mfg. date code.
If it is a 407-e 115/60Hz with a blue id plate it is at least 15 yrs old.
Nov 09, 2010 | SaniServ 407 10 Quart Ice Cream Maker
Emerson IM90 Portale Ice Maker
My friend bought this item last week at Target for the $99 sale price. The reviews were all horrible about the red light (add water) indicator going on after the first or several first ice cube runs and never going out. About 40 out of 60 reviewers had this problem. We experienced it right after the first run when the ice cube full light went on. We emptied it and the add water red light was on. I looked all over the web for a solution and only found one that suggested tilting the unit backwards for 45 degrees and that would magically reset the light. It did not after several angles, light taps and basic shaking. Since there was no alternative and everyone who returned it also got the exact same problem with the new replaced model - we decided to open it up and investigate.
The electronics diagram is on the back of the machine and tell you where the water indicator is. We took it out (an inch long black tube along the water pump and backflow valve) and dried it completely. The cycle still had the red light. We submerged it completely in water and the red light still went on saying that the unit needs water. We determined that this is the bad part and the water indicator is faulty. We cut it out and joined the two wires. IT ALL WORKS NOW FLAWLESSLY. You only have to shut the unit off when you leave since it will ocntinue to run if out of water. If you're looking for a quick mechanical fix and have a unit that works when you need it and you are around - this isthe fix.
Aug 23, 2008 | Ice Cream Makers
Freezer bowl not frozen!
Preparing the Freezer Bowl:
The freezer bowl must be completely frozen before you begin your recipe. The length of time needed to reach the frozen state depends on how cold your freezer is – for best results, place the bowl to the rear of your freezer where it is coldest. In general, freezing time is between 6 hours and 22 hours. To determine whether the bowl is completely frozen, shake it. If you do not hear liquid moving, the cooling liquid is frozen. For the most convenience, leave your freezer bowl in the freezer at all times so you can take it out any time for immediate use.
Features and Benefits:
  • Freezer Bowl – The double insulated freezer bowl contains a cooling liquid between the bowl walls to create fast and even freezing. In general, the required freezing time of the bowl is 6 to 22 hours before use. Additional freezer bowls are available separately for making double batches or different flavors without interruption. For additional information on preparing the freezer bowl for use, please see below.
  • Base and Motor Unit – The base contains a heavy-duty motor that is strong enough to handle everything from thick, rich ice creams to smooth frozen yogurts to slushy frozen drinks . The base unit features a generously sized on/off switch, rubber feet to prevent slipping and keep the unit stationary while in use as well as cord storage to keep counters neat and safe when the unit is not is use.
  • Lid with Ingredient Spout – The easy-lock, transparent lid secures to the base with a simple turn, allowing you to watch the freezing process as it progresses. An ingredient spout at the top of the lid is generously sized for pouring in ingredients and ideal for adding nuts, fresh fruit, candy pieces and more without interruption the freezing cycle.
  • Mixing Arm – The mixing arm mixes and aerates your frozen desserts and drinks, incorporating and blending all ingredients thoroughly.
  • Instruction/Recipe Book - The included instruction and recipe booklet helps you get started with over 30 recipes and variations for ice creams, sherbets, sorbets, frozen yogurts and frozen drinks.
  • Feb 29, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
    Ice Cream Makers Logo
    461 people viewed this question
    Top Taylor Ice Cream Makers Experts
    Dennis Boxerman
    J.D. Browning
    J.D. Browning
    Andrew Taylor
    Andrew Taylor
    Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
