When you switch on the dvd theres a loud buzzing noise the dvd displays F61 then it switches itself off.
Please help
david
It is a short inside the dvd
It is a short in the audio module. When you get E61 it means the audio power module is gone.
This is a common problem with panasonic, which has a terrible record with their
audio power modules. The RSN311W6B audio module from Panasonic costs about $130.00.
The whole job done in a repair shop should be around $250.
If you are lucky it can also be the the voltage regulator bad.
Part #STK470-050A $14.00.
most likely you need to change the whole audio module, or test all capacitors and ICs until you find the bad one.
