Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
My machine will only sew a stich or two then the motor still goes, but the feed dog and needle get stuck like the top thread is tangling with the bobbin. How can I fix that?
  • Kenmore Master
  • 7,365 Answers
Check you needle to see if it's damaged
check to see if the top thread to see if it's come off the thread take up lever
check to make sure there's no lint or loose thread in the bobbin area
Posted on Oct 01, 2010
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
My Kenmore Sewing Machine's needle is locked down
best suggestion try inserting new needle. cotton up the top suggests needle problem or incorrect top thread tension, this would effect the feed dog. Because thread is black and most recent use was with pink, the problem thread was already there perhaps in cavity above bobbin but below throat plate. I have had this happen and nothing will move, untill needle released. The bobbin holder tension may also need adjusting after the knots of black cotton are removed.
Nov 07, 2013 | Kenmore 15516 Mechanical Sewing Machine
Thread is tangling in the bobbin casing
Hello
The feed dogs should be in the highest position for regular sewing. If the feed dogs are not raised above the plate it will do this. With the machine unthreaded and no fabric.. run the machine to see if the feed dogs are moving and are working.
Always make sure you have about 3 inches of both threads before taking any stitches, and both threads are positioned directly behind the needle. ( this machine is fussy about this).
make sure you rethread it exactly as the owners manual shows
Change the needle
Change the thread
Take it in for service
Jul 23, 2011 | Janome Memory Craft 10000
Everytime i try to sew the bobbin sounds loose and the stitches are knotted and tangled
Hello
.Always make sure you have about 3 inches of both threads before taking any stitches, and both threads are positioned directly behind the needle.
make sure you re-thread it exactly as the owners manual shows.
Change the needle
Change the thread
Take it in for servicing
Jul 22, 2011 | Brother Sewing Machines
I was sewing some thick cloth and my needle broke. Now it want sew a good stitch. It keeps unthreading from the needle like its not feeding the thread right. I have to retrhead after I try a stich. It...
Hi, make sure there are no needle parts stuck in the bobbin/feed dog area. Also,make sure there is no lint in the same area. In my sewing experience, lint jams up smooth operation of all sewing machines.I would take apart the bobbin case, clean it and reinsert. Also, make sure that it has been oiled according to the instructions in your manual. Another issue which sewers forget about is changing needles....if there is a burr on a needle, threads break, don't feed properly, create more fuzz and eventually break. I hope this help you.
Happy Sewing.
Jul 15, 2011 | Singer 3116 Simple
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
Machine Jamming after a few stiches
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
keep a check on the thread take up lever to make sure the thread doesn't come off of it
& bobbin
Check tension 3 or 4 is usually good
Nov 23, 2010 | Brother CE4000 Computerized Sewing Machine
Thread from the top needle gets pulled and tangled into the lower bobbin.
change the needle
rethread the machine-make sure to get every thread guide
make sure the thread does not come off the thread take up lever
clean under the needle plate where the feed dogs for lint
also clean the bobbin area for lint & loose threads
Nov 20, 2010 | Brother XL-5600 Mechanical Sewing Machine
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Oct 27, 2007 | Sewing Machines
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
94 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
