Question about Amcor V22253 Portable Air Conditioner
The compressor light is on but the air is NOT cooling
  • 384 Answers
Dear sir
please make sure first your air conditioner,s compressor is working, for know that try to hear compressor sound and test by a meter check current consummation if it more than to 5 ampere then it,s mean compressor is working. and if compressor is working and unit not getting cold then it can be leakage in system .need to refill freon.
hope answer the question
thank you
please vote!
Posted on Oct 01, 2010
How do I determine if need refrigerant? Compressor is running hot and 2nd thermal protector has to be bypassed
More than likely one of your external coil cooling fans is not operating. OR Access for the fan to blow cooling air is blocked, or the cooling coil is so dirty the fan air is not effective in cooling the coil. Refrigerators are a sealed system. If the compressor has gotten so hot that the motor has burned you might as well find a lightly used replacement. It will probably be less than a repair by a qualified technician. Even if I told you how to replace the refrigerant the stores would not sell it to you. This is not a car Air conditioner! If you lost refrigerant it has probably burned the compressor motor. The refrigerant "acts" like a cooling system for the compressor motor.
Mar 07, 2015 | Danby Designer DAR440W / DAR440BL Compact...
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
The compressor light is on because the unit is cooling. It it not blowing cool "ac" air. How long is this process going to take? Do I keep the ac on or do I shut it off? It is also making a...
It sounds like the compressor isnt starting just because the lights on doesnt mean it is actually on.
If it is the compressor thats making the buzz heres what to look for when you start to hear the buzz does the fan slow down and then speed up after the buzzing stops? If it does your compressor is locked up you can try to replace the capacitor on the unit. If that dont work I wouldnt spend the money to replace the compressor too much money.
Jul 14, 2011 | Amcor AL10000E Air Conditioner
I have an Ingersoll Rand 2545 Electric Air Compressor and since the summer started it runs all day(won't shut off). At night it seems to cycle correctly but when the heat builds up during the day...
I don't know if your unit is exposed to the direct sun light if it is I suggest you create some shade , or if this this unit is enclosed is not getting enough air flow to keep cool.
( this air flow helps to stabilized the sensor that stop and start the compressor )
Sep 26, 2017 | Ingersoll Rand 2545/7100 Electric Air...
2010 Tiguan and the air conditioning switches on about an hour after we want it. the light on the dash comes on but no cool air. Just when we arrive at our destination is pumps out cool air. Thus is there...
  1. Air conditioner system is discharged. Have the system evacuated, charged and leak tested by an MVAC certified technician, utilizing approved recovery/recycling equipment. Repair as necessary.
  2. Air conditioner compressor clutch not engaging. Check compressor clutch wiring, electrical connections and compressor clutch, and repair or replace as necessary.
Apr 22, 2011 | Air Conditioning and Heat for Volkswagen...
My beverage air refrigator ri18 compressor turns on sounds like it works but doesnt get cold
1) Check the compressor working or not.. Air cooling type condenser fan may be not working properly.
2) Compressor working but not properly. Last side of condenser (Filter) Light Heat or not.
3) Inside Cooling area do not get cooling. may be gas leakage problem.
4) My opinion check Gas pressure Low and high side.
Mar 26, 2011 | Freezers
Ge window unit
Check the connection between the starting capacitor and the Start "S" of the compressor it should be connected and also the "cool light" other wire is also connected with it.
Jun 22, 2009 | GE Deluxe AGM12AB Air Conditioner
Sporadic cooling by AC on 2001 Toyota Camry 4cyl
SEE WHAT COLOR THE AC MAG CLUTCH RELAY IS / UNDER THE HOOD RELAY BLOCK IF IT IS WHITE TRY REPLACING IT WITH ONE OF THE BLUE ONES IN THIS SAME BLOCK (HORN RELAY) IF COMPRESSOR ENGAGES REPLACE WITH TOYOTA UPDATED RELAY ( PLEASE RANK THIS)
Apr 19, 2009 | 2001 Toyota Camry
Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Jul 17, 2008 | Dometic Rooftop RV Air Conditioner
No A/C
It seems that that the overload of compressor is tripping on and off, either your compressor overload is defective or the compressor itself
Sep 06, 2007 | Danby DPAC8399 Air Conditioner
Amcor V22253 Portable Air Conditioner Logo
113 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
