Question about ViewSonic VX910 19" LCD Monitor
No power to monitor despite being plugged in
I turned off my monitor one night. The next morning, I couldn't get the monitor to power up. The power button blinks very faintly, but no power to the monitor screen. Is it dead? It is nearly 3 years old. Thanks for any help.
  • wilds of pa Jun 11, 2008
    Yup we have the same problem with ours' however i changed the monitor out with another one.
    the one i changed it with does not have the dvi cable on it. just the standard monitor plug, and sound. picture is back with the change..
    My monitor is only 3 years old as well and is a 19" model #VA712B
    when we shut the computer down, it will not desplay a picture and when you turn the power on and off all it does is flicker quikly and thats it..
    Not shure if the power supply to the monitor would have anything to do with it???
    Any sug on this??
    Thanks
    Chuck
Looks like I have a ViewSonic lemon as well. 3 yrs and 4 mo old. Displays briefly then goes dark. Seems like they would have a more reliable product. No more ViewSonic for me. I'm going with a different vendor..
Posted on Jul 14, 2008
I have the same exact problem. It is just over 3 years old so the warranty is expired. Did a live chat with a ViewSonic rep and was told that I have to take it to a local shop for repairs because it appears to be a hardware issue. I happen to have another computer next to mine, so I connected the monitor to it. No change. I checked cables, turned it off and on, etc., and nothing. There are plenty of other forums on the internet addressing this issue. Some folks say it's the back light or power supply. In either case, no more ViewSonic for me.
Posted on Jun 21, 2008
    Sergeant:
  • 458 Answers
Check your video card. Is your computer booting up?
Posted on May 26, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Is your computer coming on, but the monitor is not?
    Did you check your video card?. You can put another video card in it and see if it solves the problem. You did not even let me know if you tried anything before you rated the question.
Changed the light bulb and my TV still will not come on. We have volume, but no picture.
Try unplugging the HDMI cable. Turn off the sources (complete power cycle by unplugging all from the wall and the equipment if possible). Turn on monitor and then plug in all the rest.
Jan 02, 2013 | Toshiba 72HM195 72" HDTV
My monitor doesn't go on anymore. Las night I had a pop-up appearing on the screen. I closed my computer and started over again. I'm sure I didn't turn off my monitor. Everything went well until this...
First, check to make sure the power cable is plugged properly in the back of the monitor and into the surge protector. You can try a different power outlet, but if you're still having the same problem and the light isn't turning on, it's likely you've either blown the fuse inside the monitor, or you had a power surge and blown something inside the monitor. This happens when you don't use a surge protector and just plug the monitor into the wall.
That said, if the above doesn't work then you have a hardware problem with your monitor and it needs to be serviced.
Jan 11, 2011 | Computers & Internet
I shut down my computer at night. When I come back the next morning the computer is off and the monitor is in standby with an orange power light (so far so good). When I turn the computer on, the monitor...
that blue light show and error or faulty problem internally or there a problem with in the connection or computer but first check the makers website or manual for troubleshooting.
Dec 13, 2009 | LG L1932TQ LCD Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Turn off and won't come back on
bad caps in the monitor replace the monitor or have it serviced at a electronics shop
May 10, 2008 | Balance CM2019 19" LCD Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
DCLCD 19" flatscreen won't turn on correctly
Same problem here, but after using the plugging/unplugging method it eventually stopped all together. So, I took it to a local monitor repair shop (AM Stereo, Seattle). The problem is a power supply issue where the capasitors go bad. They fixed the monitor by replacing the capacitors for $70. In there experience, all monitors, regardless of brand, tend to use the same cheap capacitors which fail. He replaced them with better quality capacitors which may make this monitor better than it ever was. I'm back in business with a great monitor!
Oct 31, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
19 "lcd gateway monitor will not power on.
Have you tried your monitor on somebody else computer?
Jun 14, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Samsung 710v no display, video
do one thing remove your monitor from cpu and turn it on only your monitor if check signal cable display is comming on your monitor means you have your cpu problume
thanks
Sep 28, 2006 | Samsung 710V 17" LCD Monitor
ViewSonic VX910 19" LCD Monitor Logo
179 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
