Question about Kitchen Ranges
I need a service manualor schematic of the Samsung FTQ352 range. I discovered a burnt out element. But I have no idea what its called. I need a diagramn showing the electrical Layout( Skematic) orservice manual. Can you help. I would like to order a replacement part.Help?
  • Kitchen Ranges Master
  • 1,711 Answers
Your Samsung FTQ352 is a newer model and th parts suppliers they don't have the schismatic diagram for the parts layout in order directly to confirm the parts you need.
However we have here below the links for three different suppliers which they have the four deferent elements of your Range and if just contact them before order we are sure that they will be more than happy to confirm which one is the one you need and you can order it directly also.
http://www.samsungparts.com/Products/Parts_and_Accessories/FTQ352IWUX/XAX/Default.aspx
http://www.partstore.com/Model/Samsung/Samsung/FCQ321HTUX.aspx
http://www.appliancezone.com/partzone/Samsung_Stove-Oven-Range_Parts.html
Posted on Sep 30, 2010
Broil element won't come on.
1. Cut power to the stove by unplugging or switching off at the mains.
2. Remove broil element and inspect for burnt or melted places, if you have multimeter, then check it for continuity, it shouldn't have more than about10 ohms resistance. Burnt-out element is easily replaced.
3. If element is good, then check for voltage at element terminals, it should be 220 volt AC ( with caution, after turning power back on and setting oven to broil).
4. If all above checks out, then the problem will require disassembling the appliance to investigate thermostat issues, relay, etc. It would be at this point that I would strongly consider putting in a service call!
Mar 25, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I need a new ovn heat element in the bottom of a Lofra 120 cm ovn type (later) which is burnt off and need to be replaced. I think is aproxamaterly on 1100 w element and have more details after a replay of...
Hi Kapshaug, this is Carlos from Lofra of Brazil. I would recommend you to contact our headquarters in Italy to help you locate the needed part for your range.
Please write to consumerservice@lofra.it or call +39 049 9904811.
Kind regards,
Carlos Fleischfresser
Lofra Sud America
Jan 17, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
My stove self cleaning light keep blinking and it will not bake. I have tried unpluging it from the wall.
check the bake element it most likley burnt out ..unplug range ..remove oven racks ..look at element with flash light to see if it broken burnt..if it is ..remove the 2 screws at the hing ..pull element out ..remove wires ..you will need model#an serial # to purchase call local appliance store for element ..or the local used appliance repair shop may have one cheap..let me know ..good luck/joe/
Aug 27, 2010 | Frigidaire FEF352 Electric Kitchen Range
Oven elements do not heat?
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
Mar 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Model MES5770AAB Serial 11517659WK The single element, 700 watts came with a wiring kit for a new connections. My range has "Old connection type 1" . the moddification kit (A-30001, Revision 4) shows...
Ten to one the elements will have to be changed also. Call or email Maytag about your dilema. You can simply reject to pay me also on this one
Jan 21, 2010 | Maytag Kitchen Ranges
My frigiaire stove element started sparking and caused smoke;called tech. Is this a common prpblem and subject to recall
Hi, yes, it's happened sometimes, to all electrical heating appliances, yes all heating elements, sooner or later will burnt out. better quality ones, will last longer, but will burnt out too, always replace with original (FSP) factory specification parts, from manufacturer.
Aug 07, 2009 | Frigidaire FES367 Electric Kitchen Range
Oven stopped working.top works fine.noticed chard insulation in back of stove.burnt wire seems to be connected to electrode in oven. any ideas?
Hi, Check voltage or continuity on the bake element. If you test voltage, there should be 240V to the element. If you check continuity, unplug the range and test the element to see if it has an open circuit. In either case, you should replace the wire connectors if they ae burnt.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 09, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Surface Burner not heating
HI, The wire that comes with the receptical also comes with wire nut and instructions. It is only a two wire receptical so you will not ned a schematic. Alos, make sure the ends of the element are clean (no burn marks) or it will ruin the ne receptical in time. Can I help further?
Vic
May 16, 2009 | Kitchen Ranges
Kitchen Ranges Logo
82 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
