Maytag Calypso Washer
My washing machine when I get it started it acts like it wants to go and then gives me a ce error message
  • 868 Answers
Replace the control board
Posted on May 26, 2008
  • Archie Ferrarini
    Archie Ferrarini May 26, 2008
    you can try this temporary fix ,Un lug the harness right where it plugs in the motor,then plug it back in again.
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Error message CE displaying. Machine will not run.
Hi, concerning the CE error, the tech sheets indicate this is a problem with the motor control board with a blown fuse on the board. The solution is to replace the board....
Oct 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso 24082 error code CE
On the ccu, the board on the right is usually the culprit, I have recently replaced one with that same error but I would first unplug it and remove and re connect each plug on the board looking for dark connections or dialysis, corrosion. If not fully insert each plug and try again.
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
CE error
There is a Rotor Position Sensor on the motor under the tub. 1st try unplugging and re-installing the sensor connector several times to clean the contacts. If this doesn't work, replace the sensor.
Mar 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Code CE
CE stands for Communication error. The Calypso has 2 circuit boards inside that touchpad area. One is the motor control board and the other is the machine control board. They are not "talking" to each other for some reason. The boards are warranted for 5 years on most machines. This machine is the subject of a class action lawsuit. Just Google Whirlpool Calypso sit back and start reading.
Dec 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
295 people viewed this question
Top Washing Machines Experts
