Question about HP Color LaserJet 2600n Printer
The red color is very faded. Therefore the rest of the color palette is faded as well. Have installed new cartridge. No help. Have cleaned and realigned heads. No help still.
    Scholar:
  • 78 Answers
This is a result of a design flaw in this engine. The laser scanner mirrors are dirty. This is a common issue as a result of paper and or toner dust in the machine building up on the scanner mirrors. It usually begins in the margins of the magenta, and moves up the machine until all of the colors are affected. The machine needs to be taken apart and the scanner assembly cleaned. I have performed this repair over 30 times wth 100% excellent results. I usually charge $75 to fix it. Contact your local tech to see if they are capable of performing the repair. If in the Sacramento, Ca area, contact Hughes Technical Consulting through FixYa to have this done.
Posted on Sep 30, 2010
I have a Samsung CLP-620ND color printer, only 1085 copies printed. After changing the 3 colored toner cartridges, my print out came out bad. Left side of paper around 3
Dear
Open the individual carts from the printer and visually observe the density of toner on the developer roller evenly. Some times the cleaning blade of ITB over come the problem.
Before this try to adjust altitude and cleaning on EPM or smart panel from PC.
Thanks.
Mar 15, 2012 | Samsung CLP620ND Colour Laser Duplex...
My CP2025 colors are not balanced. It prints purple, red, orange and yellow. Green is faded and looks yellow. Cartridges are new and look fine.
there is software cd along with printer u need to setup the software. if u installed it go to the main menu & find cartridge level. see if green is low. there are also utility like clean cartridge. use it. also reseat the cartridge. if nothing is working use new cartridge.
Sep 03, 2011 | HP Laserjet Cp2025n Printer
Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
Here are some steps you can check to resolve your issue.
Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
Here are the instruction for cleaning your printer.
Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
For more information here is the link for step by step instruction with visuals.
Hope this will help you resolve the problem.
Thank you for choosing fixya
Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
My pokemon red won't let me see it in color everything is red and people and pokeballs are green
You do not have a problem with your game or system. The original release of both Pokemon Red and Pokemon blue came with very limited color palettes. As such, your Game Boy Color can only render certain objects in a different color. For clarification purposes, both of these titles were released before the launch of the Game Boy Color so wouldn't have been given the color palette upgrade. Hope this helps.
Nov 23, 2010 | Nintendo Pokemon Red
Magenta cartridge not working despite being full
This happens due to Laser sCANNER Contamination.
Light Output that typically starts fading along the outside edges of the media. The first noticable color would be Magenta.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach eazily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Aug 27, 2009 | HP Color LaserJet 2600n Printer
Faded coloring
Clean off the bottom of your color cartridge with a slighty damp tissue to make sure the whole doesn't have ink stuck in it. If that doesn't work then its possible the ink has dried up in the cartridge and youll have to replace it. How old is the color cartridge and do you print often with it? If so if could be running low.
Feb 05, 2009 | Lexmark X1270 All-In-One InkJet Printer
Color printing
Hi, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP 2605dn laser - color fading
HP has a list of troubleshooting steps you can go through for the HP 2605dn when you experience print quality issues.
Two specific things I would try from that list are:
  1. Clean the electrostatic transfer belt.
  2. Clean the printer paper path.
Good Luck!
*If you find the solution helpful, please rate it!*
May 15, 2008 | HP Color LaserJet 2600n Printer
Color fading
Hi , the printer are dried up need head cleaning twice then test print , if color of test print are complete color no spaces ,it means head are clean .
Jan 18, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
HP Color LaserJet 2600n Printer Logo
205 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
