Question about Cameras
CCD-TR6 What if the tape door won't open, you changed the battery and it opened once, never again. CCD-TR33 I can get this one to work, but all the tapes have a static line through the middle. I took an unused still in package, but old tape and recorded and it has the same, is this the camera or the tape? Thanks for any help you can give. Esther
SOURCE: camcorder tape door opening
I had a problem the same as yours and I found the problem on the ribbon wire connected to the board where all the control button is located ( stop, rew, play, fwd pause). The problem occur because everytime you eject the tape from the loading mechanism the ribbon wire also move like your cutting it into pieces. sorry for my english hope you get the idea.... wait for the photo and i'll show you what i mean.. hope this will give you the solution you need.
Posted on Sep 15, 2006
SOURCE: Tape will not eject, and reset button does NOTHING!
I am having the exact sam problem on my PV-GS14. Have you been able to resolve the problem? If you have, how were you able to get the tape out? Thanks
Posted on Nov 23, 2006
  • 169 Answers
SOURCE: Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Posted on Aug 21, 2007
SOURCE: sony hi8 ccd-trv208e pal camcorder
Same problem, same frustration. Just flashing, won't open to insert tape, Battery relatively new. Is there any way to get it to open to put in tape? I hate this technology, not along far enough.
Posted on Feb 03, 2008
welcomejee
  • 10594 Answers
SOURCE: I have an old Sony
Try to use video head cleaning cassette one more time and check. Problem still exist then....
There is a very special cassette used to clean much dirty video heads calls Lapping Tape.
This is provided only to Sony Service Centers.
You need to contact nearest Sony Service Center.
Posted on Oct 06, 2008
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
I have the IPAQ pocket pc 3765 and I was replacing battery but when I opened I saw the battery door out of its place but I do not know where is located then I can not to finish my work. Can you describe...
Welcome to Fixya
As far as i can remember, there are no battery door for ipaq. Once the device opens, gently pry out the original battery. This one should come right off (it is only stuck using some double sided tape). All you need to do is to replace the double adhesive tape if you are going to replace the battery then close the unit. Tip: Use an old credit card or something that won't damage the case to gently lift the battery out.
Thank you for using Fixya!
Jul 04, 2011 | Computers & Internet
Just purchased a Sony TRV65, tape door will not stay shut.
This is due to relay sticking, the tape may also have a bit of rubbish plastic over one of it's holes (see underside of cas tape to make sure of this.
May 25, 2010 | Sony Handycam CCD-TRV65 Camcorder
Cassette jammed after camera dropped
I think your ejecter motor is not working.temporarily open with any tool.
Dec 10, 2008 | Sony Handycam CCD-TRV107E Camcorder
Cassette stuck
If battery is fully charged and unit still will not open, try removing the tape door and see if there is tape wrapped around capstan or ther parts. If you cannot find anything apparent, take unit to qualified pro tech
Jun 09, 2008 | Sony Handycam CCD-TRV37 Camcorder
Sony hi8 ccd-trv208e pal camcorder
Oct 31, 2007 | Video Cameras
CCD-TRV308 - TAPE DOOR WON'T OPEN
depends where the tape is located if it's still wrapped around the head i would recommend taking it in if it's inside the cassette you can have to take the door off and see if it pops out.
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
Oct 17, 2007 | Sony Handycam CCD-TRV308 Camcorder
CCD-TRV22
Yes. First, try removing the camcorder battery, then turn on the switch on the front to either camera, or player modes.
let alone for 1 minute, then turn switch to OFF or the center position, install battery ( or the Sony supplied power converter) then let the camera try to open the door. DO NOT TRY TO FORCE THE DOOR OPEN. You will kill te camera's functions for all time. Then you can sell it on ebay for parts!
Second, get a set of miniture screwdrivers, get a place where you have much light, and a place to keep the miniture screws you will be removing from the case.
Remove all obvios black screws. The best place to start is from the battery area then the bottom, then sides and finally and CAREFULLY remove the nose cover for the camera lens. Work in a warm room, as plastic will have less chance of fracturing in such an environment.
Afer all screws are removed ( just the ones on the outside mind you, carefully work the nose piece off by gently pulling anti-clockwise, the view being looking down from above to the top of the camera. Ease... this nose cone off. the door then will be a cinch, as you gently pull from the bottom of the door and it snaps off from the bottom, then it unhooks from the inside top. Again, you must use extreme care. Good luck.
Sep 27, 2007 | Sony Handycam CCD-TRV22 Camcorder
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
